Got a question about a cam
Old Apr 1, 2008 | 12:11 PM
2klen4u's Avatar
2klen4u
Default Got a question about a cam
I just purchased a comp cam 238/242 dur, lope 113,valve lift 605. 610. What is the most power a 04 zo6 has made with cam only???? The car has Kooks long tubes 1 7/8 headers and x pipe with cats, with corsa cat back. I'm just curious who has made the most power with this set up. I'm thinking of putting some trick flow head on there, but haven't made my mind up on that yet.
Thanks,
2KLEN4U
Well the results are in, and I'm very happy with the power I added by just putting this cam in. Here are a couple of pictures of the dyno sheets. There not really that clear, so you may need to pull the computer up closer ;-)
First Pull
Second Pull
Old Apr 1, 2008 | 12:26 PM
2klen4u's Avatar
2klen4u
.... I'm thinking around 420rwhp?
Old Apr 1, 2008 | 12:31 PM
nickolbag's Avatar
nickolbag
I've seen upwards of 450rwhp on cam only z06's. No clue what the most power ever would be. 420 is easy with that cam, I'd bet you go higher.
Old Apr 1, 2008 | 12:40 PM
SicMSP - Daniel's Avatar
0SicMSP - Daniel
Former Vendor
your message box is full
Old Apr 1, 2008 | 01:04 PM
2klen4u's Avatar
2klen4u
It is empty now my friend... Thanks for the info for those that have given there 411 on this ????
2KLEN4U
Old Apr 1, 2008 | 02:23 PM
2klen4u's Avatar
2klen4u
Give me a shout ... my inbox is ready for pm's.
Thanks,
2KLEN4U
Old Apr 1, 2008 | 02:32 PM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
With a proper tune id venture to guess in the 425-435 range
Old Apr 1, 2008 | 02:45 PM
2klen4u's Avatar
2klen4u
Yeah that was my guess, well I said 420. Anything over that is a plus, and will make me extra happy! I was just curious who has made the most power with cam only, also. Thanks for your input!
2klen4u
Old Apr 1, 2008 | 02:53 PM
WKMCD's Avatar
WKMCD
It really depends on who's dyno you run it on. There are some very happy dyno's out there nowadays.
Old Apr 1, 2008 | 02:56 PM
blackblack94's Avatar
blackblack94
I made 420rwhp and my cam is only a 228/232/113. I do have a Vararam though, with LT headers. Its all in the tune though really.
Old Apr 1, 2008 | 03:55 PM
2klen4u's Avatar
2klen4u
Well thats not bad numbers at all. I have a good tuner for the car. The car has kooks longtube headers, with catted x-pipe, and corsa cat back, along with Black Hawk Cai. So, I'm hoping to see sum good numbers come sat. I'll be sure to let you guys know what she made. When we "get ur dun"!!
Thanks again for everyone who has chimed in on this ?
Much Respect,
2KLEN4U
Old Apr 1, 2008 | 07:42 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
The Dyno Jet Dynos are very high number friendly
Old Apr 9, 2008 | 10:52 PM
go_mer's Avatar
go_mer
2klen4u
I was pretty impressed with what it did tonight! 434rwhp on Arthur's stingy dyno is pretty good! I wonder what it would have done without the cats? I'm pretty sure a good set of heads and a ported FAST 92 setup will get you 475 or so
Old Apr 10, 2008 | 02:02 AM
2klen4u's Avatar
2klen4u
Thanks Smokey/Gomer... I posted the two sheets you gave me. I notice one made more power than the other. I didn't look at them while we were there talking to ask why. So if you can..... Let me know why one made almost 445rwhp and the other made 434rwhp? Car is running great, and can't wait for the new heads and throtle body and intake to be put on. Im going to say we will be close to 500rwhp. NA. This is my first vette that I have not modded the **** out of. I have always built one from bottom up and threw a turbo or procharger on it. So this is a little different animal to me, and I really like it. After driving it all nite from huntsville to cullman and back to huntsville. I got really good gas millage, and I was proud of that, because I figured this cam would get into my good gas milliage!!
Much Respect,
2KLEN4U
Old Apr 10, 2008 | 08:03 AM
go_mer's Avatar
go_mer
Much Respect,
2KLEN4U
The pull that was over 440rwhp was a peak reading that was taken from a spike that you see at the end of the pull. The number, disregarding the peak, was about 3rwhp less than the very last pull. We went ahead and pulled it a little higher on that last run and there wasn't the "spike" at the end... so the peak number on the last run is a true reading.
Old Apr 10, 2008 | 03:27 PM
2klen4u's Avatar
2klen4u
Oh, ok I understand now. Thanks for explaining that to me. By the way you have mail brother. Thanks again for working on the car.
2KLEN4U
To Got a question about a cam
