Noise from steering wheel
Old Apr 1, 2008 | 01:35 PM
TimeCr0ss's Avatar
TimeCr0ss
Default Noise from steering wheel
Lately, my steering wheel has started to make this low "moaning" noise when it is being turned. It is a bit embarrassing with a passenger in the car. Anyone else have this problem?
I'm guessing getting some WD-40 in there may help..
Old Apr 1, 2008 | 01:36 PM
IDM's Avatar
IDM
check to see if your powersteering fluid is low
Old Apr 1, 2008 | 01:37 PM
TimeCr0ss's Avatar
TimeCr0ss
The noise is coming from the wheel inside the passenger compartment.
Old Apr 1, 2008 | 01:39 PM
IDM's Avatar
IDM
hmm I misunderstood, I still really dont have a clear picture, maybe someone else can help
1998whitecoupe-a4's Avatar
1998whitecoupe-a4
mine does the same thing - sounds like a goose honking.
WD - 40 would probably do it - but where do you put it?
Old Apr 1, 2008 | 01:44 PM
TimeCr0ss's Avatar
TimeCr0ss
Yes, you nailed it. I was thinking right behind the 1st joint (I think its right before the turn signal ****, etc.)
Old Apr 1, 2008 | 01:53 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
https://www.corvetteforum.com/techti...D=35&TopicID=1
1998whitecoupe-a4
anyone think spraying in there would be bad?
Old Apr 1, 2008 | 01:55 PM
1998whitecoupe-a4
Originally Posted by blacksedan87
not sure this is the problem as the noise is within the interior, but I could be wrong.
Old Apr 1, 2008 | 01:56 PM
TimeCr0ss's Avatar
TimeCr0ss
Thanks for the link. Is this for the inside of the passenger compartment?
Old Apr 1, 2008 | 02:50 PM
Ghost Vette's Avatar
Ghost Vette
I thought the something until I put the grease where the tip shows. It stop the problem. Not sure if WD 40 will stop it. You need something a bit heavier in my opinion.
Old Apr 1, 2008 | 02:55 PM
blacksedan87
WD40 is not a lubricant. WD40 displaces moisture (the name means Water Displacement, and it was the 40th formulation). The tip calls for white lithium grease - which is available in a spray. The white lithium grease will last so you don't have to do this again soon.
Old Apr 1, 2008 | 04:24 PM
Junkman2008's Avatar
Junkman2008
Randy is da' man!
Old Apr 1, 2008 | 05:12 PM
TimeCr0ss's Avatar
TimeCr0ss
I'll pick up some grease on the way home today. I can't quite tell by the picture in the above link, but where is the lower bearing? Do I have to remove anything to get to it?
Old Apr 24, 2008 | 06:25 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
TTT. I am now starting to have this problem also. I also can't tell from the picture above where the lower bearing is.
Old Apr 24, 2008 | 11:41 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
bumpity bump
To Noise from steering wheel
