Flat question
Old Apr 2, 2008 | 08:34 AM
vicsvettedreams's Avatar
vicsvettedreams
Default Flat question
Im new here to the C5 forum...from the C4 world...lol! Im loving my C5. This is probably one of the first questions people have about a used C5. What do you guys used to fix a flat on non run flat tires?
Old Apr 2, 2008 | 08:41 AM
DefenderC5's Avatar
DefenderC5
A cell phone and a flat bed tow truck.
Honestly, I've only been driving for 12 years, but I've never had a flat. That doesn't mean I won't, but it the chances of actually getting one are low. Low enough that the improved handling and ride of a non-runflat outweighs the risk IMO
Old Apr 2, 2008 | 08:50 AM
R Devil's Avatar
R Devil
Plug & patch. Just like any other tire.
Old Apr 2, 2008 | 08:56 AM
vicsvettedreams
I dont have a flat tire now. I was really looking for some info about where to buy some tire seal & a compressor incase I do get a flat. I have heard some talks about a package deal for this issue. Thought most here used the same stuff. Im in the Dallas TX area, and would like to pick this stuff up somewhere if possible...rather not mail order. Thank you all.
Old Apr 2, 2008 | 09:11 AM
steve8's Avatar
steve8
Most, if not all fix a flat cans are bad for the sensors.
Double check to be sure.
Old Apr 2, 2008 | 09:28 AM
Storm Cloud's Avatar
Storm Cloud
Does anyone know a brand of fix a flat that will NOT ruin the sensors?
Old Apr 2, 2008 | 09:52 AM
jrose7004's Avatar
jrose7004
A plug kit and small compressor.
Old Apr 2, 2008 | 10:04 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Tire Slime allegedly will not damage the TPMS - this is a link to their web site's FAQ on the matter....
http://www.slime.com/index.php?p=faq#answer_1111_loc
Old Apr 2, 2008 | 10:55 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Good to know because even though there have been hundreds of tire posts and will be hundreds more.....I still do not know which path I will go down when I need new tires. Right now I have the factory GY's with 14K on them.
Old Apr 2, 2008 | 02:43 PM
blacksedan87
For those of you that have read that the Tire Slime will not damage the TPMS, here's something for you to consider. This stuff is applied through the valve stem, by removing the core (Schrader valve) and then the stuff is squeezed into the tire. What this means to me is the stuff goes through the TPMS. I'm still not 100% convinced this a good idea.
Then the company makes a disclaimer that their product should not be used with chrome wheels - which makes me wonder if the product is corrosive against the chrome, or maybe it doesn't seal properly if the leak is a result of the bead.
In my case - and many others with aftermarket wheels (particularly with wheels that are not OEM replicas - not originally designed to accomodate TPMS), I am not using the TPMS as the valve stem. My TPMS are banded and epoxied into the wheel cavity and I utilize a simple valve stem.
They further state the their product is water soluable, but I wonder if you can effectively wash the product out of the valve stem on the TPMS.
The fix-a-flat junk in the aerosol can will gum up the TPMS and supposedly irrepairably ruin them.
I just wanted to make my understanding clear so someone doesn't make an expensive mistake without understanding the consequences - either potential or real.
AAA and a cell phone might still be the best alternative......
Old Apr 2, 2008 | 02:57 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Good post not totally sold on Tire slime either.
Old Apr 2, 2008 | 03:01 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
I got a compressor for Christmas and cookrent just sent me a blackjack plug kit. Hopefully I never have to use it!!
Old Apr 2, 2008 | 11:38 PM
Whiteonrice's Avatar
Whiteonrice
You might check to see what was in the Z06 tire repair kit. I know it had a small compressor but I don't know what they use to seal the holes. All I have is AAA and a phone. Haven't been stuck by a flat in 45 years so I'm hoping that streak holds up for another 45.
Rick
Old Apr 3, 2008 | 08:52 AM
When I had non-runflats on my car, I carried a plug kit and a small portable air compressor. I also had a cell phone and emergency road service on my car insurance.
If you are running sensors in the wheels, you don't want to use any fix-a-flat stuff as it will damage the sensors. Of course, in an emergency, that might be your only recourse.
To Flat question
