REAR Lowering Bolt Kit
Old Apr 2, 2008 | 02:46 PM
cheatoes's Avatar
cheatoes
Default REAR Lowering Bolt Kit
is this worth the 50$ or could i just go to home depot and buy a bolt?
Old Apr 2, 2008 | 03:35 PM
taz03's Avatar
taz03
just go to home depot and get them. make sure they are grade 8 bolts with nylon lock nuts.
Old Apr 2, 2008 | 04:50 PM
FKING1's Avatar
FKING1
Old Apr 2, 2008 | 04:57 PM
TrplBlk01's Avatar
TrplBlk01
Old Apr 2, 2008 | 05:00 PM
cheatoes's Avatar
cheatoes
Ok sounds good, What is the size & dimentions on the bolts I need? I don't feel like taking the old bolts out just yet
Old Apr 2, 2008 | 05:32 PM
hotwheels57's Avatar
hotwheels57
You won't find the same Metric sized bolts (or longer) at any home improvement source (14mm). You'll have trouble finding the same Metric sized bolts (or longer) at specialty sources.
You might check with McMASTER-CARR for the 14mm in a longer length.
You can also go to C5 Tech, click on search this forum (in the red banner) and use keywords "lowering c5" or similar for hundreds (thousands?) of past posts that have instructions, images and sizes of the various sized (SAE) bolts that some members used.
If you go cheap on this, you may suffer bolt failure. There's some past posts on that as well.
Old Apr 2, 2008 | 07:05 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
$29.99...
http://www.customcorvetteaccessories...weringkit.html
Peace
Chip
__________________
..................Click for
Old Apr 3, 2008 | 04:59 PM
FKING1's Avatar
FKING1
9/16 x 8" will work. Gr 8.
Old Apr 3, 2008 | 09:44 PM
Tom Porter's Avatar
Tom Porter
The 9/16" Gr. #8 is stronger and is a fuzz larger than stock but will still go through your stock bushings. I installed 8" (stock are 6") and you will get at least a 2" drop in the rear.
Old Apr 3, 2008 | 09:47 PM
mac_05evo's Avatar
mac_05evo
Or if you don't have the time to go and look for all the bolts like me, you can buy this one off of eBay for $20. Worked perfect for me!
http://cgi.ebay.com/ebaymotors/ws/eB...MEWN:IT&ih=018
Old Apr 3, 2008 | 10:05 PM
2000lambovette's Avatar
2000lambovette
Zip products sells the front & rear C-5 lowering bolts as a combo for $39
Old Apr 3, 2008 | 11:04 PM
Turbofrc's Avatar
Turbofrc
Great kit, offering for $21.99 now
To REAR Lowering Bolt Kit
