lowering help
Old Apr 2, 2008 | 08:16 PM
lilzane's Avatar
lilzane
Default lowering help
I lowered my 2003 Zo6 yesterday. the front is not turned down all the way, about 1 turn away from max. both side adjusted even. but the passenger side wheel well gap is about 1/2 higher, so i turned it down even more, still 1/2 high. anybody no what wrong.
Old Apr 2, 2008 | 08:18 PM
Blown 346's Avatar
Blown 346
You will have to drive the car for it to start to settle. This will take a day or two.
Old Apr 2, 2008 | 08:28 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Old Apr 2, 2008 | 08:33 PM
DRKMATTER's Avatar
DRKMATTER
St. Jude Donor '09-'10
I have both front bolts totally removed for over 2 years and still have a small amount of difference in gap. Think of it this way...no one can see both sides of your car at the same time, only you will know it. But I agree that it needs to settle, a few hundred spirited miles should do it.
Old Apr 2, 2008 | 08:37 PM
2000lambovette's Avatar
2000lambovette
It could also be your body panels, try measuring the frame to ground.
Old Apr 2, 2008 | 10:03 PM
Tom Porter's Avatar
Tom Porter
Front bolts removed here also.
Old Apr 2, 2008 | 10:14 PM
Tom Porter's Avatar
Tom Porter
When I lowered mine down I took measurements before I started so I knew exactly how much each corner was being lowered. I found that I had anywhere from a 1/4" to 3/8" diffences from one side to another. After being lowered and driven to settle the suspension I found that each side is now within an 1/8".
To lowering help
