Changing coolant
Old Apr 3, 2008 | 11:28 AM
krawfo's Avatar
krawfo
Default Changing coolant
I've searched everywhere on this forum but can't find a thread with tips on changing coolant.
Can any help?
Thanks!
Old Apr 3, 2008 | 11:33 AM
bucwheat's Avatar
bucwheat
Just drain and flush it and refill with DEXCOOL.I' did mine 6mts. ago.
Old Apr 3, 2008 | 11:37 AM
Blown 346's Avatar
Blown 346
I agree.
You can get more extensive on this if you want. Pull wither the lower radiator hose or the lower radiator plug and let it drain.
Put the plug back in the radiator, or put the hose back on.
Fill the radiator with all water, let the engine run until it warms up, **** it off. drain again. Repeat until you get pure water coming out. Then refill with dexcool.
Old Apr 3, 2008 | 12:13 PM
stingray71's Avatar
stingray71
Default coolant/antifreeze change
Check out this thread. You might want to also search the "Tech" forum for "antifreeze" and you'll find more info.
http://forums.corvetteforum.com/show...ght=antifreeze
Old Apr 3, 2008 | 04:46 PM
50th@50's Avatar
50th@50
Bro., it`s not like you just pull the petcock open and 12 quarts or so fall out, without the right equipment, the coolant in the block stays there. Don`t be like me and read the owners manual expecting the stated amount to be replaceable at home, it is more involved than that.
Good luck,
To Changing coolant
