[Z06] New z06 owner HELP!
Old Apr 3, 2008 | 08:16 PM
jld04z06's Avatar
jld04z06
Default New z06 owner HELP!
I have a 04 that only has 14,000 miles on the the car. Whenever I wash it though, it leaks? I did some research and see that I am not the only person with this problem. It leaks on my passenger side and I have located the leak. When I spray water on top of the car going down my molding water seeps in by the seat belt holder and runs down to the floor. If I am facing the car, passenger side I spray water on the top of the car heading to the back bumper. This is when the water comes in. It doen not leak anywhere else that I can find. What is the name of the molding on top of the window called? Would it make a difference replaceing rubber molding on back left side of window, or just adjusting the window? I dont think so because it appears to stay dry on the inside of window as well as the headliner. Any help would be greatly appreciated.
Old Apr 4, 2008 | 11:59 AM
CSShelby's Avatar
CSShelby
If you're washing your car there is no need to be "spraying" water on your car. I agree the seal SHOULD be better, but if a heavy rain doesn't get through you just need to take it easy with the hose while washing your car.
Old Apr 4, 2008 | 02:54 PM
only59's Avatar
only59
My thought is that this is not a serious issue, a nagging thing maybe but a serious issue, no.
When you put a hose on a car that is like a torrential RAIN , I think every now and then my 01 Z06 has a similar kinda leak around the passenger window if I get too crazy with the hose.
If thats the worst thing you have found U dun good !
congrats on a great car...
t
Old Apr 4, 2008 | 06:57 PM
jld04z06's Avatar
jld04z06
I appreciate the coments from the both of you. I should have been more specific though I guess. When I said spray I should of explained that this is nothing more than a mist realy just to get the soap off. I guess I should drive it in the rain to see what happens and how bad it is I guess. Can you tell me if it is hard to remove the weather stripping? If I do this project would I need new weather stripping or can I just reuse mine if it does not tear after it has been sealed?
Thanks for all of the help guys.
Old Apr 4, 2008 | 07:57 PM
garo's Avatar
garo
i'm having the same issue when i leave the car out and its raining heavy. Although I couldnt pinpoint exactly where the leak happens, its definatelly on the passenger side.
To New z06 owner HELP!
