Wheel Problem
Old Apr 4, 2008 | 02:20 PM
Enemy's Avatar
Enemy
Default Wheel Problem
So when I had my 01 Cobra I had purchased a set of black wheels with chrime lip, rears are 18x10
fronts are 18x9.5, both have stock tire sizes. Sold the cobra (cuz they suck) and bought the vett, well i still got the wheels and thought they would look awesome on the vett. Jacked up the rear, and the black wheels bold on perfect and look great, get the front up and the front holes wont match up with the studs, off by about 1/4th of an inch... WTF is that something common... Now the black wheels have 10 hole patters so are universal and neither pattern bold on...Any ideas
Old Apr 4, 2008 | 02:39 PM
Enemy's Avatar
Enemy
anyone???
Old Apr 4, 2008 | 02:49 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The correct Mustang Cobra bolt pattern is 5x114.3 and a Corvette is a 5x120. So that's 5.7mm off. (which is about 1/4").
The Corvette OEM offset is 56mm in front, and 63mm in back, which much more than the typical Mustang offset which is near as I can determine is about 40mm.
Bottom line - those wheels will not fit a Corvette.
Old Apr 4, 2008 | 02:57 PM
Enemy's Avatar
Enemy
will they fit a trans am or a camaro ls1 model
Old Apr 4, 2008 | 03:01 PM
blacksedan87
I don't know - but I doubt it. I know some of the F-body guys run C5 and C6 wheels, so if they won't fit a C5, more than likely they will not fit an F-Body either. I think the F-body also uses the 5x120mm bolt pattern.
Old Apr 4, 2008 | 03:05 PM
damilleniumboy's Avatar
damilleniumboy
How much did you pay for them? I have a stang that I use as my DD, and I'm looking for a new set of wheels maybe??? What size tires/brand are you running on them?
Old Apr 4, 2008 | 03:06 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
You could sell them and buy similar ones made for the vette
Old Apr 4, 2008 | 03:13 PM
Enemy's Avatar
Enemy
i paid 750 for them, fronts are 245/40/18 some brand called Riken Raptor rears are 275/40/18 and are michelin Pilot Sport A/S tires have a lot of tread on them
Old Apr 4, 2008 | 03:24 PM
Vetteguy2008's Avatar
Vetteguy2008
Look like your back wheels second bolt pattern matches the vette but your front wheels second bolt pattern does not match the vette.
Old Apr 4, 2008 | 05:43 PM
Enemy's Avatar
Enemy
any interest in taking them off my hands???
Old Apr 4, 2008 | 05:46 PM
bucwheat's Avatar
bucwheat
Mustang should be 5 on 5 1/2,I belive chevy is 5 on 4 3/4.
To Wheel Problem
