If i need to pull my c5 out of a bit of snow to get it out of storage is their any place on the car I can safley attach a strap to
I can't help you with where to place the straps, but being from Hawaii I got to wonder if you "stored" the car during the winter WHY is it stuck in the snow?
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
If the snow is that deep that you have to pull it out you could damage the front, Use a snow shovel if possible. You don't want to pull it or drag it through the snow.
There is just a bit of hard packed snow/ice that I have to drive over to get out of the building.
Would not damage anything but I could loose traction and a tug would get it over.
Does anyone know where a tow starp can be attached if at all
Hi jdreg -
I had to pull my Z out of a snow bank once (don't ask lol) -
I put the strap around the lower control arm (both legs) on the front, and made sure that I attached the other end low on my truck -
AS long as you aren't going to have to put undue stress on it that should be ok.
I don't recommend having to do this, but sometimes situations just happen.
