Pink fluid
Old Apr 6, 2008 | 10:41 AM
joeracer49's Avatar
joeracer49
Default Pink fluid
Well it was finally 65+ degrees here yesterday and I thought what a great day for a ride. The Beastie had not been moved or started since the last weekend of November.
Removed the battery tender, made sure none of the tires were flat and fired her up. Instant startup no cranking just start. Battery tenders are amazing.
Anyway I backed her out and thought I'd take a look at the garage floor to see if she lost any fluids over the winter. None were found last summer and fall when she was at home.
Much to my surprise there was a pink oil on the ground in the middle of the rear axle. Not a lot, just what would have been a 4 month long trickle. Not even a puddle just a wet spot.
What is it?
Something to worry about?
Had a great ride, after adding just a little air to each tire. Lost about 1 pound of pressure per tire. After a great 1 and 1/2 hour ride I took her back and put her to sleep for a few more weeks before I bring her home for the summer. Had so much fun w/ her I forgot to take any pictures.
So what do you guys think about the pink fluid?
Old Apr 6, 2008 | 12:01 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
ATF fluid ??
Old Apr 6, 2008 | 12:04 PM
Fast Cop's Avatar
Fast Cop
Old Apr 6, 2008 | 01:51 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Well if you have a six speed, it could be fluid from the transmission as it uses dextron III.
Old Apr 6, 2008 | 04:01 PM
joeracer49's Avatar
joeracer49
It's an A4, sorry to I wasn't clear. Assuming its ATF and it's a very light trickle what do I do about it?
Old Apr 6, 2008 | 05:04 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Well, I would figure out the source of the problem quickly, before it damages something. The lack of a n easy way to check your fluid level kind of necessitates that it not leak.
It could be the converter or some other seal. I would wash it up an place a piece of cardboard underneath it to try and pinpoint the leak.
BTW, how many miles on the tranny ?
Old Apr 6, 2008 | 05:34 PM
joeracer49's Avatar
joeracer49
39k
Old Apr 6, 2008 | 06:22 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
39k
That's not much mileage, to be having these kind of problems. Check to make sure your cooler lines etc are tight.
Old Apr 6, 2008 | 06:41 PM
joeracer49's Avatar
joeracer49
Thanks for the help. I'll take a look at her next weekend but probably won't be driving her for 2 more weeks
To Pink fluid
