A tip to those removing BSM's
Old Apr 7, 2008 | 05:00 PM
spicytuna's Avatar
spicytuna
Default A tip to those removing BSM's
Just thought I'd give a tip to those of you who are interested in removing your Body Side Molding. (Even though it may seem obvious.)
Instead of removing all of the BSM's at once, start with just one of the 4 pieces and remove the adhesive underneath to inspect the surface. (The segment in front of the door is the suggested piece to remove.)
If your car was repainted or suffered UV damage, it'll be obvious after you remove that piece of molding but there's a small chance that your paint may be discolored in the area under the adhesive.
Of course if this is the case, it's much easier to re-attach that small segment than it is to remove the adhesive on all of your BSM's and re-glue them back to your car.
The chances are very small but it happened to me. I removed all of my BSM's at once and only after I removed the adhesive did I notice the discoloration. I tried claying it and polishing it but it made no difference. I'll be taking it to a professional later this week but it looks like it'll require some wet sanding to remove. If that's the case, I may consider reattaching the BSM's.
Here's a pic of the discoloration :
Old Apr 7, 2008 | 06:34 PM
jdmvette's Avatar
jdmvette
Night Owl for life
wow you can't get that to come off?
bummer, man.
hopefully you will find a solution short of putting them back on.
Old Apr 7, 2008 | 06:54 PM
spicytuna's Avatar
spicytuna
It looks simple doesn't it? I tried claying and polishing but it didn't come off. I was tempted to try some rubbing compound until a friend of mine warned me not to try it unless I knew what I was doing. He also sent me a pic of what could happen if I screwed up.
Old Apr 7, 2008 | 07:00 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi FRC Ken -
That is very good advice - remove one of the small front fender pieces before you go all the way.
Have you tried Meguires Scratch X?
It is very good at removing "stuff" from paint that otherwise could not be removed.
Since this blemish looks like an outline of the bsm, it occurs to me that it is either foreign matter, or some sort of pitting on the clear-coat.
If it is foreign matter, then I think the Meguires would be a good thing to try.
Good luck, thanks for the tip, and the pictures.
best regards -
mqqn
Old Apr 7, 2008 | 08:24 PM
serotta's Avatar
serotta
The picture makes it appear to be the marks left by the tape. I used Bug and Tar remover on mine.
Old Apr 7, 2008 | 08:26 PM
vertstr's Avatar
vertstr
Old Apr 7, 2008 | 08:29 PM
dobewillie's Avatar
dobewillie
try some alcohol
Old Apr 7, 2008 | 09:28 PM
PewtVette's Avatar
PewtVette
OP, how many miles on your vehicle?
Old Apr 7, 2008 | 09:32 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Even try Goo Gone... I used that on mine and it worked great....
Old Apr 7, 2008 | 09:33 PM
MyOwn69's Avatar
MyOwn69
WD-40? Sorry 'bout that, man!
Old Apr 7, 2008 | 09:41 PM
WWK888's Avatar
WWK888
I am pretty sure that will come off with any of the suggested products. I would start with Goo Gone, then alcohol.
Old Apr 7, 2008 | 10:52 PM
spicytuna's Avatar
spicytuna
Hi,
Thanks for the suggestions. The car only has 26,000 miles so I was surprised to find these marks.
It definitely isn't any adhesive since there's no discernible edge or boundary layer via touch. I've used Goo Gone along with some 3M Adhesive remover and it made no difference.
I talked to a local member of another forum who's recognized as the detailing guru and he's offered to look at my car later this week using a paint microscope. (Who knew there was such a thing.) He also offered to try a couple of things using his orbital.
I'll keep you all up to date.
Ken.
Old Apr 7, 2008 | 10:59 PM
pettvette's Avatar
pettvette
CI 5-6-7-8-9-10-11 Vet
Unless your car has been painted, those marks will come out with a fine compound and a buffer. Just make sure you find someone who knows what they are doing and uses foam pads.
My car looked the same way before I used the buffer on it.....
Old Apr 8, 2008 | 12:47 AM
moserbe's Avatar
moserbe
I love my BSMs.
Old Apr 8, 2008 | 12:53 AM
nextime's Avatar
nextime
Ah that will buff out.
Old Jun 10, 2008 | 12:53 AM
BrandonAGr's Avatar
BrandonAGr
So I started removing my BSM, and it looks like at least the one fender I started on was repainted at some point with the molding still on there. Glad I started with just this piece!
Isn't that what this looks like?
Old Jun 10, 2008 | 12:57 AM
WWK888's Avatar
WWK888
link doesn't work. Not authorized.
To A tip to those removing BSM's
Old Jun 10, 2008 | 01:52 AM
BrandonAGr's Avatar
BrandonAGr
Old Jun 10, 2008 | 02:23 AM
ZEEEEOOOOSIC's Avatar
ZEEEEOOOOSIC
Can of worms, removal doesnt look any better to me
Old Jun 10, 2008 | 02:35 AM
BOUT X's Avatar
BOUT X
Corvette Cowboy
That sucks man I did my 2000 Chevy Silverado and removed all my badging had the same problem. Went to L.P.S and bought Mothers Clay Bar kit and BAM all gone. It comes with clay bar some carnauba cleaner and detail spray worked like a champ give it a try my Badgeing was on the truck for 8 yrs.
