Radio bezel surround
I don't think it would be that difficult to make a tab to extend out the back of the bezel, my only issue is what would I attach the tab to the back of the bezel with? Does not have to be that pretty (as it's not within any sight but it just need to be secure.
Is there a epoxy or some type of glue that I can get that will bind the two pieces to gether properly? As cutting a tab out of plastic should be easy enough to do.
I need to take the bezel off anyway, to run the power cable for the garmin 760 behind it sometime over the next few weeks anyway. Might as well fix that while it's off.
Thanks,
Thanks,
