wheels 2003 Annv Edition
Old Apr 8, 2008 | 12:46 PM
rwl106's Avatar
rwl106
Cruising
Default wheels 2003 Annv Edition
After carefull searching, my dealer promised me that they could mount new tires without scratching wheels. Well, did they ever screw up! My question is -What type of coating is on those wheels and can it be fixed or are new wheels the only answer.
Old Apr 8, 2008 | 12:58 PM
50th@50's Avatar
50th@50
That is why going into a tire change out I`m asking about 'no touch" machines. I noticed a larger Corvette store sells AE mag wheel 'touch up paint", I doubt it works really well, but wish I knew, could use it a little if it did, anyone know ?
rws.1's Avatar
rws.1
clear coat.
their body shop can wet sand and re-clear if they are only paint scratches...
If the metal has been gouged then they need to go to a wheel refinisher
Old Apr 8, 2008 | 07:05 PM
Gray Weasel's Avatar
Gray Weasel
Default wheels
If they screwed them up they should fix them or replace them no questions asked .... if not go to small claims court
Old Apr 8, 2008 | 08:33 PM
emquad46's Avatar
emquad46
Go on the web: phenixwheels.com
They repair or sell reconditioned wheels. I cracked my right front wheel on a pothole. I bought a recondition Anniversary Edition front wheel . It balanced perfectly and looks great.
Old Apr 8, 2008 | 11:55 PM
bestvettever's Avatar
bestvettever
Default AE Wheels-Titanium Color
Hi, I feel your pain, I have an AE vert that I'm going to get new tires for in a few weeks,(can't stand the GY runflats), and I have the same concern that you are experiencing. I'm going to look for an experienced tire store that has the right equipment, and personel to handle it properly. If yours are scratched, a good buffing with a new kind of clear coat polish,(it actually smooths and flows the coat back to smoothness) will probably work, if the scratches are through the paint, than to look really right, they will need to be repainted, you can touch them up, but if you are like me, it will probably not satisfy you. The wheel paint is called Champagne and dupont makes a version of it, called light warm nickel metallic.
Good Luck
Corrected info --Thanks Trigger Creep
Old Apr 9, 2008 | 01:55 AM
Trigger Creep's Avatar
Trigger Creep
http://www.50thregistry.com/technica...aintcodes.html
GM name: champagne
DuPont name: light warm nickel metallic
Old Apr 9, 2008 | 08:33 AM
Mac11's Avatar
Mac11
House of Wheels has 'em for a steal. Make 'em buy you a whole new set.
Old Apr 9, 2008 | 06:03 PM
You can try and get them repaired, but if that doesn't turn out well, make the shop buy you new wheels. That's what they carry insurance for.
To wheels 2003 Annv Edition
