Question on headers
Old Apr 9, 2008 | 06:02 PM
rcs128's Avatar
rcs128
Default Question on headers
I'm one of those Vette types that enjoys working on my car and gets a big sense of accomplishment for just turning wrenches myself. I've done oil changes, swapped brakes, replaced shocks, spark plugs, done the double DIN mod, ripped out the interior to install a stereo, etc, and I'm not intimidated at the thought of seeing parts of my car all over the garage floor.
That said, I've never really gotten into the more serious upgrades like headers and cams. But now I'm thinking of headers. My questions:
Are they going to affect everyday enjoyment and drivability? Will I even notice more noise?
Can they be installed in my garage with the car up on 4 jackstands?
And finally, I'm a big believer in "you get what you pay for." So if I were to get headers, is there a brand/type that's a no-brainer as far as quality and fit? (I'd also want to maintain the cats, btw).
Thanks in advance.
Rich
Old Apr 9, 2008 | 06:13 PM
BanditDude's Avatar
BanditDude
1. Drivability will not be impacted. You will definitely notice a sound increase relative to your starting point. I started w/ GHL Bullets, so it's on the LOUD side.
2. I installed mine on jack stands (front) and ramps (rear).
3. I had pretty good luck w/ my LG Street headers, and the quality is phenomenal. I did have to enlarge the converter outlets a bit and tweak an air fitting, but it wasn't a big deal.
Good luck!
Old Apr 9, 2008 | 06:14 PM
OleStraightStick's Avatar
OleStraightStick
St. Jude Donor '08
i did mine on jackstands.. front has to be fairly high up.. yes they will affect daily driving- will make it much more enjoyable to drive! ... most people will reccomend ARH, LG, or Kooks.. have fun
Old Apr 9, 2008 | 06:17 PM
02MillenniumVette's Avatar
02MillenniumVette
LG Pros
Old Apr 9, 2008 | 06:32 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
I let my tuner do the install. At the time I had no way to get the car up high enough to try it myself. Supermaxx by Dynatech w/ HF cats and X-pipe. Superb quality and fitment, but not cheap!
Old Apr 9, 2008 | 06:39 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I will say that the car is not alot louder - it's a little louder at all but WOT....then it's like someone unleashed the fury of Hell! Okay - maybe that's a slight exaggeration..... It's deeper at idle, a little louder running through the gears and significantly louder at WOT. Beyond that, no driveability issues at all.
I did not install them myself - I had it done along with some other stuff at the same time. I have GHL headers that have been Jet-Hot coated. I am in no position to recommend one brand versus others, all I can say is I'm happy with the results. My SOTP gauge tells me I picked up a little in the mid-range....the car is feels a little quicker and pulls a little stronger, not so much from a standing start.
Old Apr 9, 2008 | 06:51 PM
rcs128's Avatar
rcs128
Thanks for all the replies so far... keep the opinions coming!
Old Apr 9, 2008 | 07:53 PM
Hrdtop00's Avatar
Hrdtop00
I recently installed a set of LG streets with cats. I installed them in my garage using only ramps, jackstands and floor jack. Quality of construction is great on the LGs.
I only notice a big difference in sound at WOT. It is a BIG diff at WOT. You'll love it!
Old Apr 9, 2008 | 07:58 PM
Vega$Vette's Avatar
Vega$Vette
Did LG Streets on my Kids FRC last year. Impressed with the quality, fit, sound. etc. IMHO the best buy in Corvette Headers.
Installed myself with Rhino Ramps and Jack Stands.
btw. I have Kooks on mine.
Old Apr 9, 2008 | 08:45 PM
tiojames's Avatar
tiojames
Headers definitely increase the noise because of the long tubes. I bought Jet-Hots headers(ceramic coated inside and out for about half of the cost of some of the better known vette tax brands. They have been on almost three years now, look as good as new and zip problems. Good luck with whatever you choose.
Old Apr 9, 2008 | 09:20 PM
rcs128's Avatar
rcs128
This is great... I'm really learning a lot and really appreciate the input. A couple more questions:
What is the benefit of coated headers? Longevity of appearance?
And I assume the difference between long tubes and shortys is that the LTs run the full length down to the exhaust while shortys just go from the block to the cats?
Rich
Old Apr 9, 2008 | 09:33 PM
LTCHAPPA's Avatar
LTCHAPPA
I had the pro's install my Kooks LT headers.They do not effect your drivability at all,they add a real nice power increase.My car got alittle louder under normal conditions and screams at WOT. I have Corsa's so my exhaust was not loud to start with.
Old Apr 9, 2008 | 10:01 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
I had American Racing Headers installed at ECS along with high flow cats and X-pipe. It does make the car sounds better IMHO. Love it... Mine are not coated and still look good. Then again mine is not a DD and never goes out in the rain and is only driven in the rain when I have no choice....
To Question on headers
