Im trying to find the name for this part so i can find it to buy one. Its the big aluminum piece that supports the sway bar in the front that is directly below the steering pump and the pulleys for the motor. Mine is broke right where the sway bar is connected. What is this part called?
Thanks,
Justin
Reason: On a 1998 c5 corvette
i borrowed this pic from MrWaynesWorld. do you see the part in this pic?
Its the front aluminum piece that the lower a'frames and and sway bar is mounted on to. The piece that extends from both sides and is under the engine.
