What's the purpose?
Old Apr 10, 2008 | 09:29 PM
Jet-Jock's Avatar
Jet-Jock
Default What's the purpose?
I wonder what is the purpose of the two large indentations in the nose. I can understand the brake cooling ports but the other two? Sure they house the fog lamps but what about air flow?
Surely that doesn't make for a smooth air flow nose over the hood. I would think air builds up in there and the following flow gets burbled as it travels over the air in those pockets and the sleekness of the rest of the nose. C6 flow is totally different, so it makes me wonder about the C5 nose.
Wonder if it creates a down force on the nose?
Any history about the design?
Your thoughts?
Old Apr 11, 2008 | 03:50 AM
DefenderC5's Avatar
DefenderC5
There are also inserts with open holes to allow air flow. A Vararam would definitely make that area functional As far as the original design concept of the closed-off inlets, your guess is as good as mine
Old Apr 11, 2008 | 10:45 AM
indy300's Avatar
indy300
I bet it is just GM styling. The same could be said about the slits on the back bumper area near the bottom.
Old Apr 11, 2008 | 10:52 AM
02MillenniumVette's Avatar
02MillenniumVette
Those are heat extractors for the mufflers.
Old Apr 11, 2008 | 11:17 AM
kre8ful1's Avatar
kre8ful1
Old Apr 11, 2008 | 11:18 AM
indy300's Avatar
indy300
i was waiting for that reply...
Old Apr 11, 2008 | 11:31 AM
Not sure about the downforce issue, but the openings do not allow for any airflow to the engine unless you open it up. Just there for a place to put the fog lights I guess.
Old Apr 11, 2008 | 11:58 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
On a Z06 they're fully functional and provide cold air the the intake and sweep heat away from the motor out that flows out the side coves.
Old Apr 11, 2008 | 01:12 PM
Jet-Jock's Avatar
Jet-Jock
There's has to be some reason the designers and engineers incorporated them. They weren't there on the C4 nor the C6. C4 had lenses over the fog lamps that nearly made them flush, and C6 had nothing even similar.
Surely this question doesn't stump CF!
Old Apr 11, 2008 | 01:39 PM
OhioDave's Avatar
OhioDave
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
Originally Posted by Cobra4B
On a Z06 they're fully functional and provide cold air to the intake and sweep heat away from the motor out that flows out the side coves.
Correct
Old Apr 11, 2008 | 01:43 PM
indy300's Avatar
indy300
correct, but i think the general design of the front fascia was in stone before the thought of the details on the Z06 option. Unless letting air in was always the intent, but concluded sealing them off was benificial for the coupe and convertible.
Old Apr 11, 2008 | 01:47 PM
Jacks02's Avatar
Jacks02
Maybe the front slits were put there by a designer who liked the front of his 1992 Ford Probe GT.
Old Apr 11, 2008 | 01:49 PM
rcs128's Avatar
rcs128
I think it's jus part of the Corvette legacy styling. Starting with the C2 the center of the car was visually "split" with the ridge running down the center of the hood, then the C3s had the front plate area flanked by grilles (which did send cool air to the radiator) and then the C4 continued that theme (not sure if there was cooling functionality on the C4). So the C5, then, was just evolutionary.
And really, they are "functional" -- their function is to help make the car look good.
Old Apr 11, 2008 | 01:52 PM
Jet-Jock's Avatar
Jet-Jock
C4 gets its air in the same fashion as C5, from underneath.
The lenses were solid. I think there was an aftermarket nose for the C4 that had slits in it.
Old Apr 11, 2008 | 01:55 PM
indy300's Avatar
indy300
best explanation.
Old Apr 11, 2008 | 02:02 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Jet-Jock -
I submit that in 1997 they may have already had designs on the performance model (Z06) and may have designed the car this way to accommodate later performance alterations.
I also question your assumption that these areas would cause turbulence over the hood of the car. I don't think that would be the case.
At speed, air would "fill" those openings and provide a buffer, and in my opinion, there would be little or no aerodynamic loss as a result of that cavity.
That is just my opinion, since I have no facts to back up my assertion.
I will add that the C5 is still one of the best designs in terms of aerodynamic flow, one of the reasons they get such great mileage at highway speeds.
Interesting topic that I had never really though about before.
best regards -
mqqn
Old Apr 11, 2008 | 02:36 PM
Jet-Jock's Avatar
Jet-Jock
A valid argument however I based my assumption for turbulence on that air building up in there and air flowing from one direction against air trapped or even attempting to flow out of the inlets would be much different then a smooth flow of consistent material as seen in the C6 nose. I initially thought it wouldn't be an issue but then that trapped air would not necessarily be static and is trying to flow back out against the in flow. Hence my burble theory.
Yes I agree that the C5 had one of the lowest co-efficient of drag of most cars on the road. The C6 did improve on that value too.
Yeah I figured I'd throw this one out just to see if someone has the straight scoop from GM design. Could be some interesting theories as well as practical application in what they learned during wind tunnel tests.
Old Apr 11, 2008 | 03:09 PM
Cobra4B's Avatar
Cobra4B
On the coupe/vert the openings are closed off to keep the engine bay cleaner. On the Z06 they're opened up for additional cooling and colder air for the intake.
To What's the purpose?
