[Z06] iPOD interface
Old Apr 11, 2008 | 01:00 PM
Bracati's Avatar
Bracati
Default iPOD interface
Anyone have an iPOD connected up to there stock Z radio? what did you use as an interface - brand, PN, contact would be useful. thanks,
Old Apr 11, 2008 | 02:13 PM
Milan's Avatar
Milan
2 ways of doing this that I know of, I ordered both to see what I would decide on:
1) Universal Ipod2car w/ PXHGM4 harness
2) Spec.Dock from www.2point5.com
Both of these allow volume control, skipping forward and back, etc. from the factory receiver and also charge your ipod. They are also direct connections for best quality AKA no FM transmitter garbage.
Old Apr 11, 2008 | 02:41 PM
kmzizzle's Avatar
kmzizzle
Are you allowed to control through YOUR IPOD instead of say a deck?
If not, what would allow you to do that
Old Apr 11, 2008 | 04:43 PM
p_dubya's Avatar
p_dubya
the iSimple iPod2Car set is awesome. I recently installed it. It allows you full control with the ipod click wheel and also enables your factory radio controls for volume, and track selection.
iSimple iPod2car kit ISGM73 and you need the PXHGM4 (the numbers are something like that...i may be off by a letter...but you get the point) wiring harness. I dunno if i can post an address of a good website that sells em cuz they're not a forum vendor...but i'll PM it to you.
Old Apr 11, 2008 | 10:43 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
I hooked up the iSimple. Direct plug in to the harness, controls selection through the stock radio.
Old Apr 12, 2008 | 12:17 AM
Joy of 6's Avatar
Joy of 6
this is what I just had installed. Works really well and the connecter folds away in the center counsel, out of site
Old Apr 12, 2008 | 12:57 AM
stingraymarc's Avatar
stingraymarc
after reading several posts on the forum, I went with the spec.dock and its great..I really like the way it sits in the cup holder so that I can reach it and use the wheel if necessary, but still use the bose for skipping songs and volume control. It was about a 30 minute install.
Old Apr 12, 2008 | 01:11 AM
TM-Z06's Avatar
TM-Z06
Which p/n did you get???
Old Apr 12, 2008 | 02:30 AM
dkny_stylez's Avatar
dkny_stylez
so if i buy the "gm" ipod2car setup it wont work? I have to buy a separate harness?
Isn't there a way to use your ipod wirelessly within ur vehicle? I think it may plug into the cig lighter tho? I thought i saw something like that a while ago in stores..
Old Apr 12, 2008 | 02:42 AM
Milan's Avatar
Milan
Guys I just received my spec.dock today and learned something important.
The spec.dock full kit is the EXACT SAME THING as ipod2car + PXHGM4 harness, that's what is included in the kit.
So the only thing spec.dock does is proves the cup holder mount
Old Apr 12, 2008 | 02:43 PM
p_dubya's Avatar
p_dubya
you can use your ipod wirelessly if you like. you just need a radio transmitter. you can buy those just about anywhere. they plug into the cigarette lighter for power, and they transmit your ipod audio through an FM frequency that you tune your radio to. that's always an option but you sacrifice sound quality big time.
To answer your other question...the GM ipod2car kit is the one you want...you just also have to buy the extra harness. the harnesses that come with the kit are meant to plug into the cd changer wiring that supposed to be in the trunk....but we dont' have that in the Z.
Old Apr 12, 2008 | 02:51 PM
dkny_stylez
i do have the 12 disk changer in the back of the car, so does that mean i already have it?
Old Apr 14, 2008 | 03:53 PM
Bracati's Avatar
Bracati
thanks for the input. I have the FM trasmitter. It's ok on our boat, but certainly a loss in sound quality.
Where did you purchase the iPOD2car? Is the +PXHGM4 also a requirement. Someone mentioned the need for an "extra harness" what harness is this?
30 min installation sounds good. Last - what are you paying?
Old Apr 14, 2008 | 05:25 PM
dkny_stylez
well i got the aux2car setup, and the harness won't fit...So now I realized I will need the "PXHGM2" to hook it up to the back where the cd changer is..
Old Apr 15, 2008 | 07:46 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have the Peripherral ipod2car interface, works great. The PXHGM4 cable will integrate behind the factory head unit.... if you have the trunk mounted CD changer and you want to interface to that harness you will need PXHGM2.
Old Apr 15, 2008 | 05:09 PM
SIINSI's Avatar
SIINSI
Here's a little how to I wrote up a few years ago...
I got my new iPod Nano in the car last night. I snapped a few pics during the process so hopefully it can help anyone else wishing to do the install.
The interface is a Peripheral interface. When I bought the interface it came with a short(12" Long) adapter cable for the Vette. Unfortunately I don't believe the Z06's have pre-run cables to the trunk. This wasn't a big deal for me as I just cut one end of the plug off(Keeping the end that plugs into the Peripheral unit) and hardwired it to the 2 port plugs found in the passenger kickpanel/footwell.
Step 1:
Take out your footwell panel and your passenger kick panel/door sill.
Step 2:
Locate the 2 port plugs that you need to tap into. Optionally you can buy a harness that actually plugs into these plugs but, I believe it's about $40 or so and then you are left with about a 10 ft. clump of wires and nowhere to run them.
You can solder or use what I call the poke and wrap method. Which is where you cut out about a 3/4" piece of insulation, poke the wire with a test light to open it and then thread the wire through, close it and wrap the wire around and tape it up.
Here is a pic of the 2 plugs you are looking for:
Use this as your guide as to what colors from the Peripheral harness go to what colors on the port plugs.
Plug 1:
White to Connector Brown+White
Red to Connector Green+White
Orange to Connector Black+White
Plug 2:
Blue to Black Connector thick Orange
Brown to Black Connector Black+White
Black (smaller gauge wire) to Connector Dark Green
Step 3:
Remove your ashtray.(Hopefully you smokers don't smoke in the Vette) Take the plug that plugs the iPod into the interface and run it through the hole behind where the ashtray was. Peel back the carpet so you can see the wire and pull it through.
Step 4:
Find location for Peripheral interface. I mounted mine above the fat harness pictured below. It's a pretty tight fit but, I held it up with a few wire ties as well. Plug all your plugs into the unit before mounting. Making sure of course to wire tie all your wires nice and neatly and out of the way.
Step 5:
Double check all your connections and close everything up.
Step 6:
Plug in your iPod and enjoy
Half Open...
Fully Open...
Fully closed WITH iPod Nano inside!
iPod Nano in hand...
Keep in mind that the iPod Nano is tiny. If you have a different iPod you will likely need to choose a different mounting location like the armrest, glove box, etc.
Miguel
Old Apr 15, 2008 | 07:35 PM
Jaxian's Avatar
Jaxian
Default Warning to Gen I and II iPod owners.
Please remember as an aside for early adopters. If you have a Gen I or Gen II iPod, meaning it has no bottom docking port, NONE of the above things are going to work. You have to use the generic PXDX and PXHGM2 or 4 harness depending on whether you have a disc changer setup in the car. This stuff from the Peripheral Elec company. Also no control of the iPod whatsoever. Sucks to have the older stuff. But no DRM crap, if you don't know what that is then don't worry about it.
To iPOD interface
Old May 29, 2008 | 01:41 PM
00vette6spd's Avatar
00vette6spd
2nd Gear
I am planning to hard wire the audio2car interface to the harness in the passenger foot well. Are the stated wire colors for the PXDX model?
Old May 29, 2008 | 02:58 PM
mikes04z's Avatar
mikes04z
I picked up the iSimple kit from Best Buy for $99+tax. The previous and original owner of my '04 Z06 had installed a factory CD changer, so the install took me 10 minutes after I plugged into the harness. Truthfully, most of that 10 minutes was just running the cable from the back to the front of the car. No sweat.
And just to clarify - I don't own an iPod - this interface works for the iPhone, even though it doesn't say the iPhone is supported on the box.
Old Sep 22, 2008 | 10:43 PM
JimMorrisonfan67's Avatar
JimMorrisonfan67
2nd Gear
Hi,
Are all c-5 corvettes wired for a cd changer from the factory or is this wiring only done when the car comes with a factory changer. The reason I asked is I have the prev mentioned ipod kit (ISimple) and the guys from best buy said I didn't have a a cd changer wire in place. I would have to go to the dealer and have one installed.
Anybody have any info on getting this done?
Ro
