Question for Pewter Vette owners
Old Apr 11, 2008 | 05:52 PM
mhorton01's Avatar
mhorton01
Default Question for Pewter Vette owners
Is there a rattle can paint that's an "exact" match for the Pewter factory paint? I am ordering the front license plate insert and I don't want to leave it black. It's small enough that I think I can get a away with painting it myself.
Old Apr 11, 2008 | 06:04 PM
STL94LT1's Avatar
STL94LT1
You can get a spray can at your local GM dealer. Think Jim Trenary Chevrolet quoted me ~$11/can.
Old Apr 12, 2008 | 02:36 AM
PierEagle's Avatar
PierEagle
The front license plate surround has a pebbly finish. I sanded mine with 400 grit and finished with 600 grit to get a smooth finish. Bought a spray can of Dupli-Color, Truck, Van and SUV T408 Pewter (it is metallic) at Advance, for about $7 and a can of Dupli-Color Truck, Van and SUV T125 Clear Top Coat for about the same price. After sanding was complete, washed frame with a little detergent and water, rinsed good and dried thoroughly with paper towel. Sprayed 1st coat of Pewter, let dry for about 3 hrs. Lightly sanded again with 600 grit. Washed in plain water, dryed thoroughly, shot 2nd coat of Pewter. I let it sit overnite, wiped with soft, clean cloth and shot the clearcoat. That was a year ago. No chips or peeling and the color, if not exact, is so darn close I didn't have a problem with it.
Cheers
Old Apr 12, 2008 | 05:08 AM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Holy crap Pier Eagle....sounds like you have some autobody experience!
Thanks for sharing...
Old Apr 12, 2008 | 07:25 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Cheers
What? Only one coat of clear, and no wet sanding?
Old Apr 12, 2008 | 12:49 PM
98am's Avatar
98am
Default Test it first! make your own swatch
Use a blank white sheet of copier paper and spray a least three coats
to ensure the base white paper no longer shows thru and in no way affects the real color, and let dry.
Set it next to the area to be painted and compare.
Touch-paints even GM brand have slight differences.
Good Luck
Old Apr 12, 2008 | 12:59 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
pewter is one of the harder colouor to match
Old Apr 12, 2008 | 01:10 PM
PierEagle's Avatar
PierEagle
Not really. I'm retired so I like to piddle and learn by doing. Currently, I think I have about a 30% screw-up rating.
Cheers
Old Apr 12, 2008 | 01:32 PM
coujac's Avatar
coujac
I painted all of my engine parts and engine cowl with Duplicolor from Autozone. I think it matches great!
Check out this link for pictures.
http://forums.corvetteforum.com/show....php?t=1894274
Old Apr 12, 2008 | 10:56 PM
mhorton01's Avatar
mhorton01
Thanks for all the advice! Ordered the paint at the dealer today, guess now I need to order the actuall frame.
Old Apr 13, 2008 | 05:48 AM
guppie's Avatar
guppie
St. Jude Donor '08
Getting ready to do the same thing on mine, ordered my paint from the dealer Friday 4/11/08 already got the insert last week.
Best of luck to the both of us or anyone. Ordered enough paint to do my fuel rail covers too. Good Luck!
Old Apr 13, 2008 | 06:38 AM
vetter79's Avatar
vetter79
Duplicolor T408 Pewter matches great. Available at most parts stores. I got mine a Advance Auto.
Old Apr 13, 2008 | 07:50 AM
yaknow's Avatar
yaknow
got mine at NAPA, here are the results
Old Apr 13, 2008 | 08:09 AM
ZO6 Lee's Avatar
ZO6 Lee
St. Jude Donor '08-'09-'10
Very nice. Is that a C6 shift ****?
Old Apr 13, 2008 | 09:13 AM
3whit's Avatar
3whit
Default Express Paint
These guys specialize in Automotive touch up paint. When you order it you give them the last 5 numbers of your vin and they will send the correct Paint. Mine is light Pewter Metalic and it was perfect. there number is 1-877-962-3800 ,or www.Expresspaint.com Hope this helps you good luck with your mod..
Old Apr 13, 2008 | 09:33 AM
B-Vette's Avatar
B-Vette
Nice painting there guys! I've always been told that Pewter is one of the toughest colors to match too.
Old Apr 13, 2008 | 11:43 AM
yaknow's Avatar
yaknow
C6Z06 shifter installed when all the other parts were out.
To Question for Pewter Vette owners
