VIN decode request
Old Apr 13, 2008 | 01:38 PM
arobber's Avatar
arobber
Default VIN decode request
Can someone decode this VIN?
1G1YY22G045110176
Thanks!
Old Apr 13, 2008 | 04:55 PM
TraceZ's Avatar
TraceZ
That vin is for a 2004 coupe. What do you want to know about it?
Old Apr 13, 2008 | 05:48 PM
arobber's Avatar
arobber
Default options?
Can options and packages be determined from the VIN? Are there really any free VIN decoders online?
Old Apr 13, 2008 | 06:02 PM
elitedood's Avatar
elitedood
http://www.analogx.com/contents/vinview.htm
its basic but its free
Old Apr 13, 2008 | 06:31 PM
arobber's Avatar
arobber
Default Vin
Thanks, I have seen that one.
Old Apr 13, 2008 | 06:34 PM
RAMMAN's Avatar
RAMMAN
Pro Mechanic
St. Jude Donor '16 thru '26
Here you go.
VIN 1G1YY22G045110176
VEHICLE BUILD
Merchandising Model : 1YY07 -2004 CORVETTE COUPE
Gross Vehicle Weight Rating : 1681 kg (3707 lb) Order Number : GQGVMJ
Build Date : 10/10/2003 Build Plant : 145Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C2L - ROOF PACKAGE DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - 50-STATE EMISSIONS
F55 - MAGNETIC SELECTIVE RIDE CNTRL GU6 - REAR AXLE 3.42 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI V8 - 350HP
MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - 6-SPEED MANUAL TRANSMISSION
NK4 - LEATHER WRAPPED STEERING WHEEL NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN QF5 - HIGH POLISHED ALUMINUM WHEELS
SLM - STOCK ORDERS T82 - TWILIGHT SENTINEL
UL0 - AM/FM CASSETTE STEREO UV6 - HEAD UP DISPLAY
UV7 - WINDSHIELD ANTENNA UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U1S - CD 12 DISC CHANGER, REMOTE U52 - ELECTRONIC INSTRUMENTATION
VDC - VEHICLE INFORMATION CD VM3 - CONSUMER INFORMATION LABEL
V49 - LICENSE PLATE FRAME: FRONT V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN 1SZ - PREFERRED EQUIPMENT SAVINGS
10U - ARTIC WHITE 67I - LIGHT OAK INTERIOR TRIM
673 - LT OAK SEATING TRIM
Old Apr 13, 2008 | 06:52 PM
arobber's Avatar
arobber
Default Vin
Thanks for the help. I am in the process of trying to acquire that 8800 mile car and could not get that detailed information from the selling party. I certainly appreciate the time and information provided.
Old Apr 13, 2008 | 08:44 PM
Mongolink's Avatar
Mongolink
Default cool!!
looks like it set up nice !!! good luck with that
Old Apr 13, 2008 | 11:02 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
and it's Arctic White
Old Apr 14, 2008 | 10:58 AM
DAVZ06's Avatar
DAVZ06
Cruising
Can you Please run another for Me thanks in advance
1G1YY12S735123777
Mike
Old Apr 14, 2008 | 08:06 PM
arobber's Avatar
arobber
Default Option Codes
How do you determine Option Codes from a VIN?
Old Apr 14, 2008 | 08:33 PM
T VETTE's Avatar
T VETTE
Just wondering......how much for the car????
Old Apr 14, 2008 | 09:15 PM
RAMMAN's Avatar
RAMMAN
Pro Mechanic
1G1YY12S735123777
Mike
Here you are.
VIN 1G1YY12S735123777
VEHICLE BUILD
Merchandising Model : 1YY37 -2003 CORVETTE Z06
Gross Vehicle Weight Rating : 1611 kg (3552 lb) Order Number : FXZQ3Q
Build Date : 02/28/2003 Build Plant : 135Y
OPTION CODES
AR9 - BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
DD0 - ELECTROCHROMIC MIRRORS: INSIDE REARVIEW&LEFT OUTSIDE REARVIEW DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL FE4 - RIDE & HANDLING SUSPENSION SYSTEM
FFS - FUEL SYSTEM GMX215-GMX245 PULL-AHEAD GU6 - REAR AXLE 3.42 RATIO
IP4 - TRIM INTERIOR DESIGN - AR9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS6 - 5.7L LITER SFI V8 - 405HP
MN6 - 6-SPEED MANUAL TRANSMISSION M12 - 6-SPEED MANUAL TRANSMISSION WITH OVERDRIVE
NC1 - CALIFORNIA EMISSIONS LEV NC7 - FEDERAL EMISSIONS OVERRIDE
NE1 - 50-STATE EMISSIONS NK4 - LEATHER WRAPPED STEERING WHEEL
P12 - CAST ALUMINUM WHEEL R9U - GM ACCESS - AUTOBOOK IDENTIFIER
SLM - STOCK ORDERS UN0 - AM/FM STEREO W/CD PLAYER
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U52 - ELECTRONIC INSTRUMENTATION
U73 - FIXED MAST ANTENNA VDC - VEHICLE INFORMATION CD
VM3 - CONSUMER INFORMATION LABEL V49 - LICENSE PLATE FRAME: FRONT
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XFW - FRONT TIRE-P265/40R17
YFU - REAR TIRE-P295/35R18 1SA - CORVETTE Z06 BASE EQUIPMENT GROUP
1SZ - PREFERRED EQUIPMENT SAVINGS 19I - BLACK INTERIOR TRIM
194 - Z06 INTERIOR - BLACK 79U - MILLENNIUM YELLOW
Old Apr 14, 2008 | 09:20 PM
RAMMAN's Avatar
RAMMAN
Pro Mechanic
GMVIS, it is basically is a GM database that dealers access to look up info on a GM car based on the Vin#
Old Apr 14, 2008 | 10:46 PM
arobber's Avatar
arobber
Ah ha, insider information, I like it.
To VIN decode request
