Correct offset For 19x10" on C5
Old Apr 14, 2008 | 10:41 PM
CarskinZ's Avatar
CarskinZ
Default Correct offset For 19x10" on C5
Guys I know the stock offset is 64-65mm will a 79mm offset work and if not can anything be done to correct it? Please let me know
Old Apr 14, 2008 | 11:30 PM
Bill Vett's Avatar
Bill Vett
No not on a 10" rim. Sorry.....
Old Apr 14, 2008 | 11:48 PM
ljthe2nd's Avatar
ljthe2nd
I'm not sure it won't fit. I was told a 19 X 11 with the stock offset would fit on the rear of a C5 without any modifications. and a 19 X 10 with a 79 mm offset only figures to be approximately 1/8 closer to the frame. If you go by the math if a 19 X 10 with a 64 mm offset works ok, then a 19 X 10 with a 79 mm offset would need a 15 mm spacer (approx just slightly smaller than 5/8")
Old Aug 25, 2008 | 05:21 PM
bluedevil99's Avatar
bluedevil99
Old Aug 25, 2008 | 10:04 PM
Floman's Avatar
Floman
I just put a set of 2008 C6 "Gumby" wheels on my 02 ZO6 yesterday. The 79mm offset is too far inboard without any spacers. I put a 1/4" spacer just to get them bolted up to see how I liked them on the car. In reality they will require about a 1/2"-5/8" spacer to be in the correct position. I am building a set of 5/8" hubcentric spacers at work this week and will have to change out the studs for longer ones. Once thats done everything should look right.
I wanted to try this new style C6 wheel since seeing them on the 08-09 Vettes. Just something a little different than the norm. Here are some pics I took this evening. This will give an idea of how they sit with a 1/4" spacer. I will post some more pics once the 5/8" spacers are on.
Floyd
To Correct offset For 19x10" on C5
