FAST 90/90 Installed :)
Old Apr 15, 2008 | 12:12 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Default FAST 90/90 Installed :)
Last week I had ECS install a FAST 90/90 intake setup on my H/C 2000 coupe. This however is not the off the shelf FAST plenum..I sent the intake manifold to Tony Mamo of AFR so that he can perform his porting magic and maximize the potential of my latest mod. The results were outstanding! To those who are running a H/C setup, adding a FAST90 wakes up the car even more. I highly recommend it!
My setup:
224/228 .581.588@114 comp cam
AFR 205 heads milled .020
Kooks 1 3/4 headers
Blackwing CAI
Z06 Intake
4.10s
Here is my previous dyno sheet with 3.42 gears:
416RWHP/383 RWT
Heres my dyno after the FAST90/90 with 4.10s
429RWHP/402Tq
So after calculating in the gears, I gained 24RWHP and the TQ jumped to 402! Im estimating the dyno would have read 405HP before the intake swap. (-10hp reading) Not that I care much about dyno numbers anyway...its how the car runs on the street that matters to me the most....believe me its different now!
After John@ECS bolted down the new FAST, Doug takes it out to the street and then hooks it up to the Dyna Pack for a re-tune. As usual, his tune is dead on! I have zero loss in drivability with the addition of the FAST. no bucking, no surging,no compromise! There was no loss in low end TQ. Throttle response is so much nicer..makes the car alot more fun to drive. The big improvement is after 4k RPM and up...the car pulls harder all the way to redline. Just more power across the board...its awesome!
Thanks to ECS and Tony for making my car more enjoyable to drive.
Here are some pics of the go fast goods...
FAST 90 returns from Tony
Ported LS2 TB by Tony
Old Apr 15, 2008 | 12:28 AM
fallen's Avatar
fallen
From: Upper West Side, NY Very Downtown Houston, TX
NICE. I'm in the market for one also! Clear your pms.
Old Apr 15, 2008 | 02:44 AM
kingsey's Avatar
kingsey
Thinking about picking up a used 90 this summer
I'd love to know how much the porting cost. Please PM me if you dont mind
Old Apr 15, 2008 | 02:57 AM
427CPE's Avatar
427CPE
Congrats. In every case I've seen, using Fast intake combo always results in power increases. had the same here and glad i did it.
Old Apr 15, 2008 | 04:10 AM
Very nice bump up in hp and torque.
Old Apr 15, 2008 | 08:37 AM
9secondflat's Avatar
9secondflat
question- you have afr heads, a nice cam, fast..pretty much a whole recipe car... how come others post 460-480rwhp with the exact same set up and your down by 30-40 rwhp?? others post 420-430 with just a cam..... either your numbers are correct and others are highly inflated or something..... can anyone else "chime" in with their opinion???
your using the tony package that made 500 rwhp in his car... i would think with the same set up you should be 470-480 at least...
Old Apr 15, 2008 | 08:39 AM
B-Vette's Avatar
B-Vette
Great intake you have there, the FAST is an engineering marvel for sure.
WKMCD's Avatar
WKMCD
There are some very happy dyno's out there...
Old Apr 15, 2008 | 09:06 AM
CraZee ZO6's Avatar
CraZee ZO6
224/228 wont make that kind of power
you want 475+ you need a cam well into the 230s
Old Apr 15, 2008 | 09:25 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
The cam he is using is pretty much the same one I use in my blower setup, so he is ready for the blower and big power, though you got some good N/A power now
Old Apr 15, 2008 | 09:54 AM
BillY2KFRC's Avatar
BillY2KFRC
Awesome results Ike. Bet the car is an absolute blast now. Plus you still have amazing street manors with that small cam.
Old Apr 15, 2008 | 10:10 AM
nickolbag's Avatar
nickolbag
Was your ls6 intake before the Fast install ported?
On an ls1 I would think 450rwhp on the high end. I have a similar setup and am hoping for 440rwhp after I do my Fast install. If my bottom end wasn't so bad I would be hoping for 450rwhp.
Old Apr 15, 2008 | 10:31 AM
paint it black vette's Avatar
have had my fast on for about a month. pulls real nice up top and raised my trap times 5mph. intake and t/b are ported.
Old Apr 15, 2008 | 10:53 AM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Ikester, I am looking at a package close to yours. Are your heads off the shelf AFR 205 heads?
Old Apr 15, 2008 | 11:16 AM
427CPE's Avatar
427CPE
Have you seen these 430hp at the drags? Rarely do they live up to the hp they dish out at the dyno shop.
Old Apr 15, 2008 | 12:32 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
done!
Old Apr 15, 2008 | 12:45 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Not sure why some dynos put out different numbers then others but I can tell you one thing, Ive pulled on higher HP cars many times (closed road courses ) so im not so worried about it.
To FAST 90/90 Installed :)
Old Apr 15, 2008 | 12:49 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Originally Posted by nickolbag
Was your ls6 intake before the Fast install ported?On an ls1 I would think 450rwhp on the high end. I have a similar setup and am hoping for 440rwhp after I do my Fast install. If my bottom end wasn't so bad I would be hoping for 450rwhp.
Nope, came right from ebay and slapped onto the motor. you ahould have no prob hitting 440 as Im estimating mine at 439rwhp without the gears
dam gears...it would affect my numbers if I joined a dyno contest!
Old Apr 15, 2008 | 12:51 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
No, they were milled .020 You should really mill them for more more compression..how much milling depends on the cam your putting in.
Old Apr 15, 2008 | 12:55 PM
BT-01-vette's Avatar
BT-01-vette
1st off congrats Ike FI is just around the corner waiting for ya (come to the dark side young Sky walker). As far as the HP goes, I'm betting on cam size. I had basically the same combo on mine without the Fast 90/90 but with a G5X3 cam and it made 449rwph 412tq not to mention my AFR heads were milled to 59cc if memory serves me correctly (higher compression ratio). Enjoy Ike, see you soon!
