Strange Vapor
Old Apr 15, 2008 | 02:43 PM
zenohsixxx's Avatar
zenohsixxx
Default Strange Vapor
I have an 03 zo6 with heads and cam all new gaskets and bolts. They have been installed for about 6 months or more. When driving my car to temperature then shutting down and starting a little while later, there seems to be white smoke as a very fine vapor. I smell antifreeze in the air but not strong. There is no fluid coming out of the exhaust mind you I have supermaxx heads and x pipe with cats. Those are my only mods, the car has about 45,000 miles on it. There no antifreeze elaks or oil leaks on any of the motor or on the ground. Just a fine vapor with a little antifreeze aroma. Can someone diagnose this for me?
Old Apr 15, 2008 | 03:14 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
where is the smoke coming from , do you smell it inside the car? If so I am guessing heater core???
Old Apr 15, 2008 | 03:24 PM
hotwheels57's Avatar
hotwheels57
If you can see the fine white vapor and smell antifreeze coming from your interior vents, then more than likely it's your heater core (or heater system somewhere).
If the fine white vapor is coming from your exhaust, more than likely it's a head gasket that's failed or maybe heads might need re-torqued. The leak might be so small that the exhaust is burning off most of it before it exits the tailpipes in vapor form.
Old Apr 15, 2008 | 03:47 PM
zenohsixxx's Avatar
zenohsixxx
Yes, I don't think it's the heating system what so ever, there no fog in the car or anything. However I can smeel the odor in the car but its very faint. This is after romping the gas a few times. Yes, the vapor comes from the exhaust. I thought heads couldn't be retoqued. Please give me specific information. I bought new head bolts and gaskets are on the way. Any other help would be appreciated. Thanks.
Old Apr 15, 2008 | 04:37 PM
zenohsixxx's Avatar
zenohsixxx
I just ran my diagnostics:
PO135 Heated Oxygen Sensor Heater Circuit Bank 1 Sensor 1
PO155 Heated Oxygen Sensor Heater Circuit Bank 2 Sensor 1
U1160 Loss of Communications with LDCM
AO-LDCM B2282 Battery #1 Fault
AO-LDCM B2284 Battery #2 Fault
AO-LDCM U1064 Loss of Communications with BCM
A1-RDCM B2265 Horizontal Position Sensor Fault
A1-RDCM B2283 Battery #1 Fault
A1-RDCM B2285 Battery #2 Fault
A1-RDCM U1064 Loss of Communications with BCM
A6-SCM B0851 Battery 1 Out of Range
BO-RFA U1064 Loss of Communications with BCM
BO-RFA U1255 Serial Data Line Malfunction
Can someone explain to me how to fix these problems and what they actually mean?
Old Apr 15, 2008 | 04:48 PM
MagneticRed1977's Avatar
MagneticRed1977
Just a quick thought- from all the fault messages I would look for a connector or connectors, that is unplugged or loose.
Old Apr 15, 2008 | 06:14 PM
Tim01Coupe's Avatar
Tim01Coupe
I have a ground points diagram for a 2000, find one for your year or I can send you this one. That's either a wiring harness connector plug or ground, possibly removed a ground on the engine during work performed? I also had wild codes like that once from a loose battery ground.
To Strange Vapor
