Tnt C5
Old Apr 16, 2008 | 01:29 PM
Gbali's Avatar
Gbali
Default Tnt C5
I just have a quick question for anyone who has changed a fuse in the compartment under the floor mat. I can't seem to pull out the fuse #27. Is there some kind of secret I am not aware of? Is there some special tool I need to get? I have tried several times with no luck. Thanks
Old Apr 16, 2008 | 02:00 PM
damilleniumboy's Avatar
damilleniumboy
use some needle nose pliers.
Old Apr 16, 2008 | 02:39 PM
bucwheat's Avatar
bucwheat
Or twizers
Old Apr 16, 2008 | 03:36 PM
Oldvetter's Avatar
Oldvetter
I don't remember if the under-floor fuse block has one, but most fuse blocks have a tool, usually white twizers, used to pull fuses, that is stored in the fuse block, check diagram for fuses.
Old Apr 18, 2008 | 01:15 PM
Gbali's Avatar
Gbali
Default Tnt C5
Thanks to all who replied. I found the fuse like tweezers in the fuse box under the hood and it works.
To Tnt C5
