tire pressure sensor error???
Old Apr 16, 2008 | 07:19 PM
04DevilR1's Avatar
04DevilR1
Default tire pressure sensor error???
I recently swapped my wheels, but they do not have the correct tire pressure sensors...is there anyway to turn off the error code that keeps popping up on the DIC?
Old Apr 16, 2008 | 07:42 PM
Bakersfield's Avatar
Bakersfield
From your profile, I see you have a 98. If the tire pressure sensors are from a 2001-05 model, they will not work on your car. If they are the correct sensors, you may need to train them again to get them to read in the right location. Do a search on this forum for the training procedure, it is not hard to do and only takes a few minutes.
Old Apr 16, 2008 | 10:25 PM
jrose7004's Avatar
jrose7004
All that I know you can do to get rid of the message is push reset everytime you start the car.
Old Apr 17, 2008 | 04:17 AM
The '97-'00 were not able to have the sensor message programmed out like the later models.
To tire pressure sensor error???
