P0300 code
Many questions but I appreciate any and all input.
This code means multiple cylinder misfires. If your car was running fine before you filled up & then after fill up displayed the code and started running rough I agree with you that the gas has water in it.I would buy a couple of bottles of dry gas & add both or maybe three of them.You will have to put some miles on until it removes the water from the tank. Don't buy the type that contains ethanol not good for plastic fuel lines which the c5 has.When all the water is gone & your running good take the car to auto zone( etc.) & they will delete the check engine light for free, then delete the code from your DIC.A fuel filter change is recommended.
Keep us informed of your progress.
robsc501
