Spare tire for C5
Old Apr 17, 2008 | 09:43 AM
nuck's Avatar
nuck
Default Spare tire for C5
I don't have runflats on my 02. I was thinking of just just getting a junkyard front tire and rim. If I found one in between my rear and front height any reason why this shouldn't work, just to drive her home?
Old Apr 17, 2008 | 09:55 AM
DefenderC5's Avatar
DefenderC5
Yes, it would "work", providing you limp it home. The AH/traction control would need to be turned off as the difference in side may trigger it.
I don't have runflats either, my spare tire is a cell phone. It weighs less and looks better than driving around with a full wheel and tire in the back.
Old Apr 17, 2008 | 10:33 AM
87SAM's Avatar
87SAM
There is also the issue of finding a way to securely fastening the wheel down. Would not want the wheel flying around to add insult and injury incase of an accident.
Old Apr 17, 2008 | 10:35 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi nuck -
The problem will be the offset and clearance of the large brakes on the C5.
The best way to go is to contact Cleveland pick a part and purchase a late model GTO spare - it has the correct offset and will clear the brakes.
I have one that I take on road trips just in case.
You'll pay around $75, and that is for the wheel and tire combo.
best regards -
mqqn
Old Apr 17, 2008 | 03:36 PM
Vector's Avatar
Vector
Ever thought of a small air compressor (powered via cig lighter outlet), a pair of needle nose pliers, a flash light and a tire plug kit? They will all fit in your small trunk comparment and cost less than lugging a spare around. Might give it a try.
Old Apr 17, 2008 | 03:54 PM
hotwheels57's Avatar
hotwheels57
Originally Posted by mqqn
Hi nuck -
best regards -
mqqn
FYI, the GTO spare needs to have the ID of the center hub opening increased slightly to work on a C5/Z06.
The other issue is the different OD of the tire/wheel which might damage a rear axle...
Old Apr 17, 2008 | 08:57 PM
nuck's Avatar
nuck
Yes I have not intention of carrying the spare . I would keep it at home. Waiting for the auto club can be 3 hours. I would sooner get the car home on my own. When I said a junkyard tire I meant one from a C5 so there would be no brake clearance issues.
The plug kit is a really good idea in addition to my spare. I will look into that.
Old Apr 17, 2008 | 09:13 PM
GUSTO14's Avatar
GUSTO14
I also have a GTO spare that I picked up for my C5. My car has the ZO-6 tires and wheels on it and the diameter of the GTO spare is the same as the front tire and slightly smaller than the rear.
Good luck... GUSTO
Old Apr 17, 2008 | 10:20 PM
Oldvetter's Avatar
Oldvetter
IF the spare tire is not close enough in diameter to your rear tire, the positraction will actuate and could burn out your positraction differential clutches.
Runflats, designed for C5s and work great. Non-runflats, you take your chances. BTW, flat bedding a C5 with a flat tire is not a damage free experience!
Old Apr 17, 2008 | 10:23 PM
Oldvetter's Avatar
Oldvetter
If you plan on using a plug kit, make sure your jack will fit under a C5 with a flat tire. Trying to plug a flat tire while on a C5 is next to impossible, especially with the rear tires.
Old Apr 17, 2008 | 10:27 PM
Tannman's Avatar
Tannman
Bad idea. Carry a tire pump and a cell phone.
Old Apr 17, 2008 | 10:56 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Old Apr 18, 2008 | 07:53 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I picked up a wheel off the forum for about $75.00 , had one of my old tires mounted on it.WHen I take a long trip I throw it the back ,and it hangs in the garage the rest of the tme. Small price to pay if I would ever need it .
Old Apr 23, 2008 | 04:07 PM
VETFEVER's Avatar
VETFEVER
Best solution
Old Apr 23, 2008 | 06:02 PM
F4 Woozzo's Avatar
F4 Woozzo
So, if you carry a spare tire, do you also carry a jack that fits under your car? Does it fit in rear compartment spaces?
I understand the worry over a flat, but the danger of a big tire sliding forward through the cockpit when you stomp on the brakes to avoid the jerk that just cut you off outweighs the wait time for a tow truck. How about that jack handle coming through the back of your seat? Anything in the back of the vehicle needs to be secured, well, or you risk having it crash around inside if you get into an accident.
(I just saw a Mythbusters on this.)
I switched from run flats to non-RFs and bought a small compressor and plug kit. You can also get a can of fix-a-flat or tire slime. Might mess up your Tire Pressure Sensor on that tire, but you saved more than the cost of a TPS by getting non-RF tires. I also have AAA.
To Spare tire for C5
