my window quit working
Old Apr 17, 2008 | 12:11 PM
Lear31A's Avatar
Lear31A
Default my window quit working
This is my first post, thanks for all the info you folks provide! I just bought a 98 model and the passenger window quit working. It makes a "click" but no attempt what so ever of moving down. The drivers side window makes a metal on metal sound about half way between travel up or down. Am I looking at breaking the bank here or something that might be somewhat common? The car only has 53K and is perfect in every other way. Thanks so much for the tips or links. Also, I have all 3 manuals..
Old Apr 17, 2008 | 12:19 PM
LT1SPUD's Avatar
LT1SPUD
check this thread out...worked for me and no problem since...
http://forums.corvetteforum.com/show...hlight=LT1SPUD
Old Apr 17, 2008 | 02:01 PM
Tom/99's Avatar
Tom/99
Hearing the click, is a good indication that the motor is bad.
Old Apr 17, 2008 | 04:04 PM
BigEbusa's Avatar
BigEbusa
I thought the click was good that the motor was still active but the regulator is failing/failed.
Old Apr 17, 2008 | 04:20 PM
87SAM's Avatar
87SAM
My driver’s side window quit working a couple days ago. I tried the fist banging method to no avail. Tried the method in the link and it worked like a charm. At first I gave a couple thunks to the forward screw and nothing happened. I then tried the screw to the rear and it worked the first time. I also must be a mutant because I didn’t need a third arm.
Thanks!
Old Apr 17, 2008 | 06:20 PM
robsc501's Avatar
robsc501
Default My window quit working
Hi There,
When you hear the clicking sound that tells you that power is passing through the relay(relay is working) & that the window motor is not operational.
The hammer therapy is only a temporary fix.
Eventually you will be changing the motor.
robsc501
Old Apr 17, 2008 | 07:55 PM
Bakersfield's Avatar
Bakersfield
Originally Posted by robsc501
Hi There,
robsc501
But, I have read here in the other posts that even a new motor may give you problems. What happens is the armature inside the motor gets stuck in the bushings and doesn't fall back into alignment with the brushes. Slamming the door hard several times causes the motor to un-stick and start working again. I would suggest you keep doing this until it stops working all together. The drivers door with metal on metal noise concerns me. That should be looked at, something may be off track.
Old Apr 17, 2008 | 10:10 PM
TEXHAWK0's Avatar
TEXHAWK0
Once it sticks, it is not long until it quits working completely.
A new window regulator assembly costs about $300 new from a dealer, or you can find the eBay seller that sells GM replacements for less.
I have already had to replace both window regulator assemblies on my 04 Z06, so yours lasted longer than average.
If it is also making noise, the cable drive system may be messed up. I would check it out before it ends up scratching the glass and you have to replace the regulator and the side glass.
Old Apr 18, 2008 | 12:13 PM
VetteFTW's Avatar
VetteFTW
I had that sound too, I changed the window regulator and now its fine. I paid about $238 shipped to my house from Rockauto.com
Old Apr 18, 2008 | 07:21 PM
Lear31A's Avatar
Lear31A
Thanks so much guys for the info. I am just getting home from a trip (I am a pilot), and I look forward to reading all the links tonite. Hopefully, tommorrow I can get out and tinker with it.
To my window quit working
