[Z06] which header primary size?
Old Apr 20, 2008 | 09:22 PM
Soundman69's Avatar
Soundman69
Default which header primary size?
On a Z06 with just a Halltech venom. Which size header primaries should be used? The 1 3/4" or the 1 7/8"? I was thinking of the AR headers with the cats x-pipe. I'm going to keep the stock Ti to start with. Need cats since we have emission checking up here.
thx
Old Apr 20, 2008 | 09:49 PM
Higgs Boson's Avatar
Higgs Boson
If you are staying relatively stock then get LG Streets (3/4). If you are going stock cubes but a cam or heads/cam get the LG Pros (3/4). If you are going FI or more cubes go with AR 7/8.
Be sure you know what your end goal is or you might wind up buying two sets of headers....
Old Apr 20, 2008 | 10:01 PM
kerryt1's Avatar
kerryt1
1.75 unless you will be going with a HUGE cam / heads or forced induction, then go with 1.875. I'm going to buy 1.75 ARH.
Old Apr 21, 2008 | 11:13 PM
Soundman69's Avatar
Soundman69
If I'm planning a cam and perhaps SC later on down the road, is it smart to do the 7/8 ARs now if the headers are my first purchase?
Old Apr 21, 2008 | 11:19 PM
Higgs Boson
Not only is it smart, it's GENIUS.
Old Apr 22, 2008 | 12:55 AM
thetorch's Avatar
thetorch
thx
Go with the 1 7/8", you will make more power over the 1 3/4" and lose nothing in the bottom. I would ask ARH about a step header, they make better power than a constant diameter header in almost every instance.
Old Apr 22, 2008 | 12:58 AM
RIDE3311's Avatar
RIDE3311
I purchased 1 7/8 LT's when I was doing a H/C combo on stock bottom end because I planned on doing a stroker setup with a blower at some point down the road.
Old Apr 22, 2008 | 09:50 PM
jpandes's Avatar
jpandes
I went with 1 7/8" LT's because I got a deal on used set I like the idea that I can use them as I climb the mod ladder.
386 rwhp/380 ft.lbs.
Old Apr 23, 2008 | 11:32 PM
tlc0706's Avatar
tlc0706
Understand H/C, etc, with 1 7/8. Thought they had to much flow for a stock system, with resulting loss of HP and torque. So his power would be way down until additional mods are performed. Right or wrong?
To which header primary size?
