Visor Removal?
Old Apr 21, 2008 | 10:08 AM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
Default Visor Removal?
I did a search and no luck, how do you remove the visors without damaging them?
Old Apr 21, 2008 | 10:17 AM
ZO6 Lee's Avatar
ZO6 Lee
St. Jude Donor '08-'09-'10
Try Remving visors in C5 Tech.
Old Apr 21, 2008 | 11:18 AM
Bob CTS's Avatar
Bob CTS
Flip down visor
Put slotted screw driver into the plastic bezel where the visor rod goes in. There is an indentation there.
Rotate the visor to the door, when you do the bezel will rotate w/ the screwdriver and it will pop out.
Wiggle the wires to allow the connector to come out.
Little bit tricky, just be careful with the screwdriver tip.
Old Apr 21, 2008 | 11:22 AM
Harley2Vette's Avatar
Harley2Vette
go to vetmods.com and click on c5 homelink .removal instructions are there
Old Apr 21, 2008 | 11:34 AM
bucwheat's Avatar
bucwheat
Why remove them?
Old Apr 21, 2008 | 11:40 AM
IDM's Avatar
IDM
Originally Posted by rspreng_Z06
Flip down visor
Just like this, its a neat process when you see it happen
Id use a paper towel under the screw drivier because you will strip/scratch the plastic if you arent careful
Old Apr 21, 2008 | 02:57 PM
NAVY08's Avatar
NAVY08
Originally Posted by bucwheat
Why remove them?
to sell them, I'm parting out a C5, thanks guys!
Link in my sig if you need any parts
Old Apr 21, 2008 | 04:57 PM
CUlookin's Avatar
CUlookin
Hey man, the visors suck to remove, I did them on mine and Yellohhh's. Be careful twisting the visor with the screw driver in the plastic ring, it will crack! Also make sure you use a towel to protect that metal bar from the screwdriver... not a fun project
Old Apr 21, 2008 | 05:09 PM
NAVY08's Avatar
NAVY08
want to come do it for me? I'm completely disassembling a C5, like every bolt, if you want to come play
Old Apr 21, 2008 | 05:37 PM
PETE O.'s Avatar
PETE O.
If the visors are black and complete, I'd like to buy them from you.
Thanks!
Old Apr 21, 2008 | 06:38 PM
moserbe's Avatar
moserbe
Which one are you parting out? Didn't you use to have a blue Vette?
Old Apr 21, 2008 | 06:49 PM
CUlookin's Avatar
CUlookin
I might take you up on that after I take my boards in June and have a week of leave. You doing this all in Annapolis?
Old Apr 21, 2008 | 07:20 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Flip down visor
What he said. It's very easy.
Old Apr 21, 2008 | 10:48 PM
NAVY08's Avatar
NAVY08
Thanks!
Drivers side is missing, Passenger side is sold, I just need to remove it.
I have a Red 2000 that is mine, I purchased a black 2000 as a donor for a FFR GTM Supercar.
Sounds good, Let me know
Old Apr 21, 2008 | 10:58 PM
CorvetteAddict's Avatar
CorvetteAddict
Wow that's amazing. Are you transferring the LS1 too or will you go with a different engine? Keep us updated!
Old Apr 22, 2008 | 12:24 AM
NAVY08's Avatar
NAVY08
Probably a stroked/ heads and cam LS2/LS3 going for 500 HP NA
To Visor Removal?
