fuel gauge chapter 2
Old Apr 22, 2008 | 09:30 AM
bucwheat's Avatar
bucwheat
Default fuel gauge chapter 2
I know this sounds like I'm but this is slightly different.When I start my C-5 the fuel gauge works fine for about 30 min.then dies to empty,It does this every time I start it after sitting all night,it has happened 25 times or more and I have added Seafoam and even a tank with Techron was no help,does this sound like a ground problem?
Old Apr 22, 2008 | 11:17 AM
GRUNIE's Avatar
GRUNIE
Old Apr 22, 2008 | 12:30 PM
bucwheat's Avatar
bucwheat
Guess no one ever had this problem,guess next step is replacement of fuel sensor in tanks.
Old Apr 22, 2008 | 01:50 PM
cinder5804's Avatar
cinder5804
Cruising
Default Gas cap
Mine does the same thing and so did my friend's C6. He said what fixed the problem was replacing the gas cap. He said that if you over tighten it (more than one click) the seal gets damaged. This causes the air leak and send the empty signal. I have yet to replace mine but he did and the problem has not come back. Good luck.
Old Apr 22, 2008 | 01:53 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Old Apr 22, 2008 | 01:59 PM
bucwheat's Avatar
bucwheat
I belong to a large Corvette club here so I'll borrow a cap and see if it goes away,If it works I owe you.Let you know.
Old Apr 22, 2008 | 02:57 PM
PostShawn's Avatar
PostShawn
Please post what you find with the new gas cap. Mine's doing similar things. I get in and it's full. I drive a few miles for a couple days and it will then randomly go to empty or low. But if I restart the car when it does that it goes back to where it should be (about 2/3rds full).
Good luck.
-Shawn
Old Apr 22, 2008 | 03:03 PM
lil vette's Avatar
lil vette
keep us posted, on the gas cap idea.
Old Apr 22, 2008 | 06:02 PM
Keppler's Avatar
Keppler
St. Jude Donor '25-'26
This is a copy/paste of a thread I posted about the repair of my fuel sending units. I started 3 threads about the fuel gauge problem and the subsequent repair.
I thought I would share the repair information of the common C5 fuel gauge problem I've had for the past 2 years (2002 vert).
Description from the repair order: Fuel gauge goes empty when it has 1/2 tank fuel showing. When filling back up sometimes gauge reads full. Customer has run out of fuel with 3/8 tank showing. Customer has noticed vehicle has 18.5 gallon tank and has run out of fuel showing 14 gallons used when refilled.
Pull TSBS Doc #1411305 fuel system diag. Test fuel pressure. Test for fuel bleed down OK. Check scan data for both sending units. Test by draining fuel from rail and watching for sending unit voltage change. LH sender changes, right does not. Check for proper fuel transfer to jet pump in right tank. Fuel coming from left sender blow out metal transfer line to check for blockage. Check for fuel at inlet for RH fuel sender. Fuel to jet pump but no fuel transfer. Needs sender unit and jet pump. Replace RH sender unit and jet pump. Scan data for senders, vehicle fuel system operates normally after repair.
Parts: 89047748 Module KI 3.107 RH fuel sender assembly $480.00
Labor 3.5 hours
Computer scan $120
Expensive repair but it's great to have a working gas gauge again. I asked if the LH tank could have a similar corrosion problem. They did not disassemble the LH sending unit but said according to all tests it is working normally.
Old Apr 22, 2008 | 06:24 PM
Keppler's Avatar
Keppler
Contained in this thread about 4 posts down shows the location of the fuel sending unit grounds. They are easy to check and clean.
http://forums.corvetteforum.com/show...+gauge+reading
To fuel gauge chapter 2
