C5 Gas Gauge
Old Apr 22, 2008 | 06:09 PM
MARC C5's Avatar
MARC C5
Default C5 Gas Gauge
I Took A Trip To Memphis This Weekend And After Driving A While My Gas Gauge Went From Full To Empty, Check Gauges Lite Came On,and Low Fuel. Drove A Full Couple Hundred Miles And Refilled Up Started Working Fine. On The Way Home Did Same Thing. Since I Been Home No Problem . Any Ideas What Going On
Old Apr 22, 2008 | 06:26 PM
c5streak's Avatar
c5streak
Fairly common problem. Try running a bottle of Techron with each of your next few fill-ups. Also only use premium, name brand fuel, most of which have additives in them to help this problem. I've run nothing but Shell premium in my two C5's for over 50k miles combined, with ZERO problems.
Old Apr 22, 2008 | 06:51 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
I use Chevron since it already has Techron in it. Exxon and Shell may also have it or a comparable additive. I've not had a problem using these fuels.
I filled up at a discount retailer one time and had the same problem you experienced. Never again.
Old Apr 22, 2008 | 09:04 PM
Gordon Vibbert's Avatar
Gordon Vibbert
Mine has been goofy ever since filling with Amoco (Sept 07). Chevron Plus, Seafoam hasn't worked. Finally found BG44K. I am hoping this works. Extremely annoying to me.
Old Apr 22, 2008 | 09:20 PM
dobewillie's Avatar
dobewillie
try some techron
Old Apr 22, 2008 | 09:51 PM
Hopefully it is only some sulfur deposits messing with your sending units. Try the Techron in the gas and see if that clears it up.
Old Apr 23, 2008 | 09:08 AM
cinder5804's Avatar
cinder5804
Cruising
Default Gas cap
My 2K does the same thing and I have tried all the cleaners and Shell only. My friend's new C6 started doing the same thing. He replaced the gas cap and that solved the problem. He said that if you over tighten the cap (more than one click) it will damage the seal and cause the pressure leak. If it works it is a cheap fix. Good luck.
Old Apr 23, 2008 | 09:09 AM
candacedianne's Avatar
candacedianne
My sister-in-laws vette is doing the same thing. Have you checked to make sure your grounds are ok? We think this might be her problem. Also, check to make sure you aren't throwing any codes. Good luck!
Old Apr 23, 2008 | 11:12 AM
MARC C5's Avatar
MARC C5
Default Gas Gauge
I Use Mobile In My Car But Ill Try Shell And Change The Gas Cap Then See What Happen. Thanks
Old Apr 23, 2008 | 11:17 AM
jdsaengine's Avatar
jdsaengine
My 03 had same problem, always bought cheap gas. Ran Tectron thru one tank and Seafoam the next. Guage started working. Month later happened again and again put Seafoam in. That was last summer, since then always use Sheel V power and have not had any problems. Just keep using the additive till it clears up.
Old Apr 23, 2008 | 11:27 AM
MARC C5's Avatar
MARC C5
Default Gas Gauge
Old Apr 23, 2008 | 12:28 PM
JH's Avatar
JH
Shell was considered problematic probably a few years ago because of high sulphur content. Sulphur is like grit at a microscopic level. I formerly used it in my C4 before moving to a C5, but I went to Conoco in my part of the world (Colorado) where there are no Chevron or Texaco stations. Either of those brands have Techron.
Try a couple of bottles of Techron, but you may want to avoid Shell.
Old Apr 23, 2008 | 12:41 PM
Muddbug1's Avatar
Muddbug1
St. Jude Donor '08
My gas gauge has been dead for a week now. I'm running Techron Plus thru it right now. I didn't have any issues at all until this past Thrursday when I filled up a Shell station. 30 mins later gauge was dead. Gonna try Chevron for a while.
Old Apr 23, 2008 | 12:59 PM
JH's Avatar
JH
Sorry to see that. Hope things straighten out, man. No Shell for this guy. It's a shame because decades ago when I was autocrossing the tweaked British sports cars I owned, Shell was THE performance gas to use, highest availble Octane in pump gas, etc. But that was before close tolerance, electronically fuel injected engines.
Old Apr 23, 2008 | 01:15 PM
bucwheat's Avatar
bucwheat
Where are the ground straps?
Old Apr 23, 2008 | 03:38 PM
Keppler's Avatar
Keppler
St. Jude Donor '25-'26
This thread about 4 posts down shows the location of the fuel sending units.
http://forums.corvetteforum.com/show...+gauge+reading
Old Apr 24, 2008 | 09:10 AM
bucwheat's Avatar
bucwheat
thanks keppler,I'll try the ground straps this weekend,that sounds like my problem.
To C5 Gas Gauge
Old Apr 24, 2008 | 09:18 AM
wit2pz's Avatar
wit2pz
Mine did that until my first road trip to Ohio in June '04. No problems since... other than rising gas prices...
Old Apr 24, 2008 | 09:33 AM
DefenderC5's Avatar
DefenderC5
That's interesting because I always had the best results with Shell/Chevron and the worst with Mobil 1. It was especially noticable in my truck w/ maggie supercharger. Shell and Chevron worked great in boost, but Mobil 1 would always ping/predetonate at WOT in boost.
Even the cheap stuff they sell on base (what I use now) was better than Mobil 1.
Old Jun 4, 2008 | 03:52 PM
oakvillec5's Avatar
oakvillec5
Default fuel gauge
BG44K, worked for me within 48 hours (100 kilometre's)
