[Z06] Window Creeks Opening Door
Old Apr 25, 2008 | 09:15 AM
netster's Avatar
netster
Default Window Creak Opening Door
My driver side window makes a creeking sound when I open my door. Does anyone know of a fix for this ? Very annoying this sound is.
Old Apr 27, 2008 | 10:58 PM
TEXHAWK0's Avatar
TEXHAWK0
First, I would try to determine where the creaking in coming from.
Is it from the top of the glass at the weatherstrip, or is it down inside the door?.
If weatherstrip, try putting silicone on the weatherstrip.
If inside the door, it could be the rubber cushions that hold the glass in the window regulator assembly. If inside the door, you might have to remove the door panel and move the glass to determine the source.
