Can't get front wheel off. Stupid problem, any tips
I know I sound like the least capable mechanic right now, which is cool because I am But I can't get the front wheel off my car. I have the lugnuts off, and I kicked the wheel and smacked it a few times to break it loose, but it's not working. i had this problem on my old Eclipse years ago and I kicked it once and broke it loose, but this is ridiculous.
Any ideas, I feel really stupid
Try the WD-40. Another trick I've used is to heat the area. There's probably a different coefficient of expansion between the hub and wheel. Good Luck.
Sounds like a galvanic reaction between the aluminum wheel and the steel hub/lugs. Soak it down with PB Blaster around the lugs, put lug nuts on loosely and tap the tap the lugs. If that doesn't do it a LITTLE heat around the lug holes will.
This sounds most reasonable, but if your using WD-40 and letting it sit and plan on using a sledge hammer, by careful and use a wooden block and if your using heat, don't go overboard as you might burn the paint on the wheel. if' it's painted. you don't want to bend the wheel.
Hi There,
The reason you can't get the wheel off is you have galvanic corrosion between the axle hub & the inner wheel boss area.Put all 5 lug nuts back on snug them up & then lower the car slowly with a floor jack( & using the hockey pucks) to the floor & let the weight of the car do the work for you.Clean all the rust on all the wheels & axle hubs before installing. Fine sand the white rust off the bottom side of each lug nut. Next time it will be a snap getting the wheels off.Been there & done it with out damage to the wheel studs or car.
robsc501
Reason: additional info.
When was last time you had them off.. location,etc could all contribute
agee with person above ( whichone right) - had same problem - put about 3 ligs back on - lower gently roll should crack loose - and problem fixed - not they guy with the big A-- hammer works every time for me for lots of things --inlcuding wife
