TPS ...What happens if I run without them?
Old Apr 27, 2008 | 07:56 PM
NEILZVETTE's Avatar
NEILZVETTE
Default TPS ...What happens if I run without them?
I just bought a 97 and I have a set of C6/Zo6 replicas from my C4 that I wanted to put on. I really would like to avoid having to break down and rebalance my new wheels. If I have to have TPS what has to be done as my sensors are for 17/18in wheels and my new combo is 18in all the way around. Thanks!
Old Apr 27, 2008 | 08:01 PM
taz03's Avatar
taz03
You don't have to have tps but you will get the mesg on the dic every time you start the car. All you have to do is reset it and it will go away. As far as wheel size it does not matter the sensors are the same for all wheel sizes.
Old Apr 27, 2008 | 08:05 PM
NEILZVETTE's Avatar
NEILZVETTE
So how do I rest the DIC.
Old Apr 27, 2008 | 08:08 PM
HummelS's Avatar
HummelS
Just tap the "reset" button.
Old Apr 27, 2008 | 08:28 PM
Junkman2008's Avatar
Junkman2008
But the message will keep coming back over and over, and over, and over. and over, and over, and over, and over, and over. and over, and over, and over, and over, and over. and over, and over, and over, and over, and over. and over, and over...
Unless you're ready to deal with that annoying problem, get TPS's.
Old Apr 27, 2008 | 08:30 PM
moserbe's Avatar
moserbe
Was that over and over again??????????????????????????????????? ???????????????????????????????????????? ?????
Old Apr 27, 2008 | 08:41 PM
Junkman2008
I have one tire that I need to relearn and that thing is nagging the hell out of me!
Old Apr 27, 2008 | 09:35 PM
NEVERL8C5's Avatar
NEVERL8C5
Last I heard if you leave them out the lug nuts have to be threaded on backwards.
If you are anything like the rest of us the reset button becomes a pia after the 3rd or 4th or 5th time.
IMO put them in.
Old Apr 27, 2008 | 10:46 PM
Plus, running the TPS is a nice safety feature.
Old Apr 28, 2008 | 12:43 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
I thought I read that later models (01 up) the TPS's can be tuned out.
Just wondering.
Old Apr 28, 2008 | 02:20 AM
Junkman2008
Just wondering.
That would be a negative, sir.
Old Apr 28, 2008 | 07:51 AM
taz03's Avatar
taz03
Just wondering.
On the later models it can be turned off through the computer. 2000 and older cannot.
Old Apr 28, 2008 | 08:45 AM
Junkman2008
You mean with a programmer. Not through the DIC, correct?
Old Apr 28, 2008 | 10:22 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
2001 and newer - the system can be turned off using a Tech II tool.
To the OP - all you have to do is break the front bead of the tires, slip the TPS in and reset the bead...then you're good to go.
Old Apr 28, 2008 | 10:53 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
What I have been doing for 2 1/2 years now and I just reset the DIC every startup
OutKlast's Avatar
OutKlast
I don't have TPS sensors and for a while the message was cleared. Had the car dyno tuned and its back and I can't get rid of it. (2000 FRC)
Old Apr 28, 2008 | 10:57 AM
rws.1's Avatar
rws.1
You will see a service tire monitor system everytime upon start-up .
Hit the reset button.... to get rid of it until the next start-up
Old Apr 28, 2008 | 12:40 PM
Junkman2008
I don't think mine works that way. After you hit reset and clear everything, a couple of minutes will pass and the stupid message starts showing again. I keep forgetting to train the sensor...
To TPS ...What happens if I run without them?
