witch clutch
Old Apr 28, 2008 | 12:29 AM
jetmech09's Avatar
jetmech09
Default which clutch
which clutch would you put on your vette, a LS-7 clutch or a Spec 2 or 3.
Old Apr 28, 2008 | 12:36 AM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
Originally Posted by jetmech09
witch clutch would you put on your vette, a LS-7 clutch or a Spec 2 or 3.
Do "witches" have clutches???
Old Apr 28, 2008 | 12:48 AM
jetmech09's Avatar
jetmech09
lol I will fix
Old Apr 28, 2008 | 01:08 AM
The NNIAL8R
lol I will fix
I wish I could help...both my C5s are automatics....My C6 Z-06 is a 6 speed of course.....but if I were to put a clutch in a C5 that had under 450 HP Id probably go with a C5 Z-06 clutch
Old Apr 28, 2008 | 01:11 AM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
keep striving for that rainbow....
Old Apr 28, 2008 | 07:28 AM
kww's Avatar
kww
Down right spooky post
Old Apr 28, 2008 | 07:43 AM
Wheelboyo's Avatar
Wheelboyo
Witch clutch
I couldn't resist clicking this one even though I have an auto!
Old Apr 28, 2008 | 07:53 AM
IMXCITD's Avatar
IMXCITD
eo
I am looking at clutches as well....but will go with something a little more stout....probably a Ram, Tex, or mcleod.
Old Apr 28, 2008 | 08:22 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
Buy a textralia. Lots of people have them and have had good results.
If you do a search you will find a bunch of threads.
Old Apr 28, 2008 | 09:51 AM
bucwheat's Avatar
bucwheat
Hell yea,and they drive Vettes too.
Old Apr 28, 2008 | 10:07 AM
JJS04's Avatar
JJS04
Cruise-In X Veteran
I have Spec 3 and it does fine with approx. 430rwhp and 4.10s.
Old Apr 28, 2008 | 10:12 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
If you're not running anything more than an LS1 with less than 400hp, I would install an LS6 clutch, LS6 master and slave cylinders.
When I replaced my clutch last year - since I have a stock LS1 with headers, I just used an LS1 clutch. It works just fine and will continue to work just fine, since I have no intention of doing any engine work.
Old Apr 28, 2008 | 10:58 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
If stock, stock is fine and when you pump up the power get the LS7 or Textralia
Old Apr 28, 2008 | 01:46 PM
jetmech09's Avatar
jetmech09
thanks for all the info !!
To witch clutch
