I just purchased a 1998 and need to know if the recall has been done. VIN # is 1G1YY22G0W5113260.
Ask your local dealer to run the vin no. They should be able to tell you. However, be forewarned, you will be told by the masses here to buy a column lock by-pass (CLB) and install it regardless. Runs under $50. I got mine from Corvettes of Houston.
Call mike at 1-800-829-6434. He can fill you in. Good guy, great info.
I installed CLB on my 02 mn6 last night and noticed that some version of recall has been done on mine..One side of the wiring harness has White wire in place of Orange..according to sticky C5 Tech. Everything went well, but am I OK..Talk of 2mph fuel cutout?
Both of us will maybe, probably need to know this info..
Ok I have found out my 98 did get a recall 04006 but has a status of open. That sounds to me like it wasnt brought in to have the recall done. Am I correct? Also how can I tell from my VIN # when my C5 was built? or for that matter somewhere I can decode my VIN #?
