C5 shocks
Old May 1, 2008 | 06:09 PM
judson whitley's Avatar
judson whitley
Default C5 shocks
Got oil change today and the mechanic said i had a small leak in the right rear shock, and i was really shocked when they said that shock cost 800.00, i have the 50th anniversary model i have an extended warranty but it covers only structs, mechanic wrote up structs but when i call back and spoke to the parts department he said is is a shock, this was a chevy dealer has anyone had problems with this it has 62000 miles.
Old May 1, 2008 | 06:13 PM
MagRedConv's Avatar
MagRedConv
Parts guy is right, our cars don't have struts. The question is whether or not your ext. warranty covers shocks (doubtful).
Old May 1, 2008 | 06:31 PM
lionelhutz's Avatar
lionelhutz
You can install C6Z shocks. They can be had for about $250 for 4 plus shipping.
If your car has the ride control, you'll have to get it turned off so it doesn't throw a code and error message. I'm thinking maybe you do from the price of the shock you listed. If you want to keep the ride control you don't have much choice except to shop around for the cheapest price. It looks like gmpartshouse.com has the rears for around $550 and the fronts for around $700.
C6Z set can be had from there for about $255. They're about the cheapest option for C5 shocks and they work good too. Well, I've seen a Monroe listing for a set they make but I don't remember the details but I think they were still more $$.
Peter
Old May 1, 2008 | 09:53 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
04 C5Z shocks, Bilsteins, C6Z and Koni FSDs are some good options that are better than the stockers
Old May 1, 2008 | 09:59 PM
MagRedConv's Avatar
MagRedConv
This may be a quick fix until you decide which avenue you want to travel - http://forums.corvetteforum.com/show....php?t=2013496
Old May 1, 2008 | 10:17 PM
GR8-LIFE's Avatar
GR8-LIFE
$800? You ca switch out to billstein sport shocks for a couple of hundred bucks. BTW, I had a leak in one of Bilsten shocks a year after I bought them and L.A.P.D shipped out a replacement for free. I sent the bad one back.
Old May 1, 2008 | 10:34 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
That wont work. The 03 has F55 shocks, not F45's. The systems are not compatible. If you love the adjustable ride, pay the money and replace the shock. If you really don't switch it much (or notice a big difference) then replace all four shocks with something like C5Z06 shocks, have the F55 programmed out, and call it a day.
Old May 1, 2008 | 10:37 PM
MagRedConv's Avatar
MagRedConv
My bad, thought it might help.
Old May 11, 2008 | 03:09 AM
Trigger Creep's Avatar
Trigger Creep
Some F55 shocks leaked at much lower mileage. Several owners had them replced during the 12 month, 12K mile period.
I thought these would be covered under GM's extended warranty too - Major Guard - But it says shocks are not covered. That Sucks. Worn shocks are one thing, but a failure in a part is another.
http://www.gmprotectionplanonline.com/majorguard - us the 'find on this page' (Edit pull-down menu) and search for 'shocks'
They are available at gmpartsdirect.com for $469 or $418, depending on which one you need. http://www.gmpartsdirect.com/catalog/frameset.cfm
Make sure to remove the shock stuffer once its installed. Replacement shocks come with a shipping block (stuffer) installed.
Hey -fill out your profile - let us know where you are. Someone might be able to recommend a dealer in your area.
Old May 11, 2008 | 08:12 AM
DefenderC5's Avatar
DefenderC5
...If you love the adjustable ride, pay the money and replace the shock. If you really don't switch it much (or notice a big difference) then replace all four shocks with something like C5Z06 shocks, have the F55 programmed out, and call it a day.
The mag ride is garbage IMO, put a real performance shock in there. You'll get a sportier ride and it will cost far less $$$.
Old May 11, 2008 | 12:39 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
When working properly you won't find a better system. Even Ferrari uses it. However, it does seem to suffer from reliability problems and as the OP has found out, parts are priced outrageously high.
Old May 13, 2008 | 09:11 AM
judson whitley
Default shocks
i really don't see a leak right now the ride still seems fine i just wonder if the dealer was after some quick repair so i will watch then probably by the ones on the net, thanks for all the imput
Old May 13, 2008 | 12:10 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I have 4 OEM shocks (non-ride control version) with abour 30k miles on 'em --- you're welcome to them if you wanna pay for packing and shipping.
PM me.
Dave
Old May 13, 2008 | 12:24 PM
buckdog06's Avatar
buckdog06
WRONG!
WRONG!
Although it's a decent system
Ferrari- Uses CDC-ZF Sachs ride control. Not the Delphi magnaride found on Corvette.
ZF Sachs supplies the shocks for the FE3/Z06 suspension (non-magnaride)
Old May 13, 2008 | 12:30 PM
spicytuna's Avatar
spicytuna
Keep your eye on the C6 parts section. Seen lots of (very) low mileage C6 Z06 shocks go for around $100 for FOUR!
Old May 13, 2008 | 08:36 PM
doje's Avatar
doje
That's because many C6 Z06 owners change to 2004 Z06 shocks. The 2004's are better.
To C5 shocks
