Tires Without Sensors
Old May 2, 2008 | 04:30 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
Default Tires Without Sensors
Can I run with tires with out the senors for a while or will i go in to reduced power mode , waiting for new tires not sure if I will have them in time for cruise in can borrow a set of z06 tires & wheels can I use them with out a problem just for the trip as my tires are in bad shape not sure if I should put another 1000 miles on them ...thanks
Old May 2, 2008 | 04:36 PM
taz03's Avatar
taz03
Sure you can. You will get a mesg on the dic every time you start it saying service tire monitor system. You hit the reset button and it goes away. I have been running no sensors for a year now with no issues.
Old May 2, 2008 | 04:42 PM
johnnyvettes
CHICAGO CREW !
thanks
Old May 2, 2008 | 05:28 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Mine is the same way. I have aftermarket wheels and the previous owner put them on. sensors didn't fit or something so he just tossed em. I get the service tire monitor system message every time I start the car too, but I just hit reset.
Old May 2, 2008 | 06:02 PM
johnnyvettes
CHICAGO CREW !
you can go to the dealer and have them turn off the sensors so you won't be bothered with that..............
Old May 2, 2008 | 06:17 PM
wamara's Avatar
wamara
Cruise-In II Veteran
I believe you can have this done only on '01+ models....
To Tires Without Sensors
