Need great big advice!
it, not because I'm trying to keep the mileage low, but because it's a little incovenient
most of the time with it being so low and all (and other stupid reasons). Love the car. I've
done all of the mods most people on this forumn have probably done... black wing intake,
GHL exhaust, 19 inch CCW wheels, cross-drilled/slotted BAER rotors, B&M ripper shifter,
Optima yellow top battery, etc. I do all the oil changes myself. The car looks new inside
and out as well as bottom with the exception of your normal nose chips from highway driving.
It sits in the garage most of the time attached to a battery tender.
So the problem is, I decided to drive it to work last week after having not driven it for
over 2 months when I noticed a few drops of liquid on the floor where it was parked.
Clear yellowish/brownish liquid which I now believe to be coolant fluid.
I put the car up on the
ramps yesterday to see where the leak was and it looks like it might be seeping through a
gasket at the very bottom of the engine. Looks like there's a tiny bit of corrosion going
on with the gasket. I can't believe it's leaking coolant fluid, the engine is so clean. So,
has anyone seen this problem before and know how much it cost to repair the problem? I'm
gonna have it checked and find out for sure in the next few days, but wanted to see if
someone else in the forum has seen this problem. It's just a gasket, but it looks pretty
hard to get to. Plus not sure what other gaskets are corroding.
I'm seriously debating trading in the car just because of this little problem. It's just a tiny
leak, but I'm worried there might be more corrosion going on.
So, anyone have any thoughts/advice?
thanks much...
then get out and drive this car that is what they were made for and you will fall in love all over again.yellowish bownish usually is not a color for coolant which is normally pink unless it is very old . What color is the fluid in your coolant reservoir
If you do decide to sell it versus fixing what appears to be a small problem, you may want to try to sell it yourself. You obviously take good care of the car and it should go to someone on this forum, or to someone who knows someone on this forum.
Hate to see your sweet lil' C5 leave the family!
Let us know what you find out, but my next stop would be a qualified and competent Corvette specialty shop to see what they can tell you.
You could have a leak test done on the coolant system while it's being flushed. It shouldn't be very expensive to see if the radiator holds pressure.
Otherwise, you could place something under the car where you suspect a leak. I usually use the disposable, aluminum oven liners. On a flat surface the fluid will not roll off (like on a garage floor). It will also not be absorbed. It makes it easier to analyze the color of the leak.
You'd definitely know if it were the transmission or the differential, since those are in the rear. It doesn't sound like brake fluid. It doesn't sound like the right color for coolant either. Yellowish/brownish liquid could be engine oil, maybe? Sometimes things look different on the floor...
Is anything low? Coolant? Engine oil? Power steering fluid?
thanks for the advice.. really appreciate it.
