Which wire is the throttle position sensor?
Old May 5, 2008 | 12:04 PM
cadallante87's Avatar
cadallante87
Default Which wire is the throttle position sensor?
I'm assuming its somewhere on the throttle body. Anyone know which color(s) it is? I'm using in place of WOT switch on nitrous install.
98' LS1
Old May 5, 2008 | 12:55 PM
cadallante87
Anyone please!!! I'm almost done and forgot my shop book at home.
Old May 5, 2008 | 01:04 PM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
On my 99 its the blue wire, on a meter, you should see 0-5V, voltage increases as the pedal is depressed.
Jim
Old May 5, 2008 | 01:05 PM
cadallante87
NVMD I think I found the correct information finally on the web.
Hook the TPS wire to the "Blue" wire coming off the throttle position sensor pigtail on the throttle body.
If this is not correct please let me know. Thanks.
Old May 5, 2008 | 01:07 PM
cadallante87
Check out my Corvette photo's there is a pic of the wire there.
Jim
Thanks Jim. I actually found your post on ls forum. Appreciate your help!!!
To Which wire is the throttle position sensor?
