[Z06] A little wiring help please.
Old May 5, 2008 | 01:26 PM
heavymetals's Avatar
heavymetals
Default A little wiring help please.
I am installing a new head unit (actually everything) and need the location of:
1. The VSS wire/connector in the dash area.
2. The back up light feed (if available in the dash/console area).
3. The parking brake feed (dash/console area).
Or if someone has a link to a wiring diagram....
Thanks in advance...
Old May 5, 2008 | 02:10 PM
jerboa's Avatar
jerboa
St. Jude Donor '14-'15
Not sure exactly what you are after when you talk about feeds......
The VSS sensor is on the top right hand side of the differential,
The back up light switch is on the right hand side of the MM6 transmission,
The parking brake switch is below the park brake in the center console.
Old May 5, 2008 | 03:13 PM
heavymetals
Thanks!
The VSS feed to the speedo is supposed to be available as it splits off to the PCM.
Looking for which wire in which connector here.
I just didn't want to run a wire all the way from the rear to the passenger seat (where everything is mounted) if one was available at the console or dash area.
Oh well, since I have to run wires to the amp (in the trunk) one more in the bundle won't matter.
To A little wiring help please.
