Taller Tires, will it effect the computer?
Old May 7, 2008 | 02:36 PM
Hysteria's Avatar
Hysteria
Default Taller Tires, will it effect the computer?
I'm putting drag radials on my car for a track day this weekend. I have 295/35/18's on the car now and I'm going to put 305/45/18's on the car.
The 305/45/18's are 28'' tall as opposed to the 26'' 295/35/18's, will the computer get all screwy with the different diameter tire?
Old May 7, 2008 | 03:03 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
As long as the back tires are taller than the fronts, you'll be fine. The taller tire has less revolutions per mile than a shorter tire, and that's what the EBCM monitors through the speed sensors in each wheel. It compares front to back wheel speed, if it senses the backs spinning faster than the fronts, it will invoke traction control.
Old May 7, 2008 | 03:24 PM
IM28702's Avatar
IM28702
Your speedo will be off as well... Just curious... Why are you going to such a tall tire?
Old May 7, 2008 | 03:30 PM
orpha's Avatar
orpha
kill your power
Old May 7, 2008 | 03:32 PM
Hysteria's Avatar
Hysteria
Thanks for the reply back. I didn't even think about the traction control being an issue.
I was mainly referring to a thread I read earlier about "changing the rear gears", and had mentioned about the speedo calibration and the car going into "limp mode". Someone said that as long as the tires are the same size, there wouldn't be any problems.
Here's the Thread, under Post #4
http://forums.corvetteforum.com/show....php?t=1986164
Old May 7, 2008 | 07:06 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
If you go with more than a 2% variation from the assumed tire diameter in the PCM calibration, you can damage your powertrain.
Old May 7, 2008 | 07:20 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
How?
Old May 7, 2008 | 09:25 PM
Chemdawg99's Avatar
Chemdawg99
Originally Posted by Mister Peebody
How?
For the reasons already posted up. The speed sensors will send mixed feedback to the PCM and interpret wheel spin and invoke the TC which in turn could cause damage to any number of things in the driveline.
Old May 7, 2008 | 10:26 PM
Hysteria's Avatar
Hysteria
I'm getting the 305/45/18's brand new for free. It's only for the track.
What if I turn TC off? Shouldn't that fix the problem??
Old May 7, 2008 | 11:13 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i run a 345/30/19 tire and it's very tall @ 27.4"OD .
i'm not sure if a 305/45/18 28.8"OD tire would even fit back there without severly modifying the wheelwell.
i know a 335/30/20 with an OD of 28.0" needs wheelwell modifications.
http://forums.corvetteforum.com/show...2&postcount=43
Old May 7, 2008 | 11:24 PM
Hysteria's Avatar
Hysteria
Chit!
Okay, thanks for that tidbit. I'm not modifying the wheelwell. I'll just see about having them exchanged for some Nitto 285/35/18's (25.91'' tall)or 305/35/18's (26.42" tall).
Thanks for your help.
Old May 8, 2008 | 03:39 PM
IM28702's Avatar
IM28702
The most likely won't fit issue is primarily why I asked. To throw in my 2cents, if it's for the track, I'd go shorter to help your gearing. I run 315/30/18's which are an inch shorter than stock and about three feet wider than stock. On factory Z06 wheels, they work great.
Old May 8, 2008 | 04:41 PM
MagneticRed1977's Avatar
MagneticRed1977
You mean it could damage my flux capacitor -oh no! I hate guesses.
Old May 8, 2008 | 05:15 PM
Hysteria's Avatar
Hysteria
I was able to trade in the 305/45/18's and get some 285/35/18's. They're a little shorter than my regular rear tires I have on now. I think they're 25.9'' vs 26.1'' of my street tires.
I mounted them and balanced them this afternoon and they're on the car with the fatory 5 spokes for this Saturday's Track day.
Old May 8, 2008 | 05:21 PM
Chemdawg99's Avatar
Chemdawg99
Very funny. What I said is not a guess, its a fact. The Corvette was not designed with drag racing in mind and aside from the TC issue you can put undue stress on the rear axle by going with tires that are 2% taller than stock.
Old May 8, 2008 | 09:47 PM
Mister Peebody
Default Uhh, No!
The traction control issues occur when the front tires are taller than the rear tires. The shorter rear tire will spin faster than the taller front tire, at any given speed, and the car interprets it as wheel spin and activates the Traction Control.
Now, how do 2% taller tires put extra stress on the rear axle?
Old May 8, 2008 | 09:53 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Old May 8, 2008 | 10:03 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
The tire will make a 10.2% difference in your speedometer reading. When your speedometer reads 60 mph you will actually be traveling at 66.1 mph. be careful if you drive to the track with them on.
Heres a web site that will calculate this information for you.
http://www.miata.net/garage/tirecalc.html
Old May 8, 2008 | 10:10 PM
Hysteria's Avatar
Hysteria
I changed the tires to to 285/35/18's. They're almost the same height as my street tires.
To Taller Tires, will it effect the computer?
