??? on 08Z shift knob
Old May 7, 2008 | 09:54 PM
LT1driver's Avatar
LT1driver
Default ??? on 08Z shift ****
will it bolt or screw on to c5 stock shifter??????????
Old May 7, 2008 | 10:02 PM
jdmvette's Avatar
jdmvette
Night Owl for life
nope, you'll need to get a modified one or change the shifter also.
Old May 7, 2008 | 11:06 PM
Dave98's Avatar
Dave98
Give Gene Culley at GMPartsHouse.com a call. I think it was about $200, but it was an easy install.
David
Old May 8, 2008 | 01:19 AM
White Rabbit's Avatar
White Rabbit
I got mine on ebay for $80
Old May 8, 2008 | 12:17 PM
hotwheels57's Avatar
hotwheels57
If you're handy at DIY it apparently can be mounted to your oem C5/Z06 shifter.
You'll need to drill/tap a hole in the side of the C5/Z06 lever (ala C6/Z06) to attach the fastener.
I don't know the oem size of the C6/Z06 fastener, but you could even use a small SAE instead of metric...
Old Jun 7, 2008 | 11:40 PM
SearayC5's Avatar
SearayC5
Do you have to modify the stock C5 shifter boot if you are completely changing to a C6Z shifter, ****, and bolt? Also I have heard mentions that it needs to be adjusted or something after install. What exactly has to be changed. i thought the stop bolts were already set up?
Old Jun 8, 2008 | 12:36 AM
wingnut037's Avatar
wingnut037
I did the install with one hand in a cast. Don't sweat it. Follow the write-ups on the forum with the correct tools and you are set. Hour tops, 2 if you stop for lunch.
Old Jun 8, 2008 | 01:34 PM
SearayC5's Avatar
SearayC5
Anyone?
Old Jun 8, 2008 | 03:10 PM
Rendell's Avatar
Rendell
You do have to modify the boot a little. Nothing major. Soemeone (I forget who) sells a Boot for a C6 shifter in a C5.
To ??? on 08Z shift knob
