Dyno Tuning... what is it?
Old May 7, 2008 | 11:55 PM
mbroadway's Avatar
mbroadway
Default Dyno Tuning... what is it?
Okay, I'm going to show how new I am to this.
What is dyno tuning?
Is there any danger to your car in doing it?
Are there usually dealers or companies in most cities that can do it?
What does it cost?
Thanks.
Michael in KC
Old May 8, 2008 | 12:06 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Q: What is dyno tuning?
A: A tuner straps your car to a dyno. He/She then connects several instruments to it to measure the air/fuel ratio, horse power and torque. They then run your car to high RPMs and measure several things. They adjust paramaters and repeat the process until they get the best results possible.
Q: Is there any danger to your car in doing it?
A: Yes. Your car is run up to very high RPMs. It should be in excellent shape with good clean oil before taking it there. If anything breaks, it is not the tuners responsibility unless they did not strap it down correctly.
Q: Are there usually dealers or companies in most cities that can do it?
Dealers will not do it. You need to search in your area for a good shop. I suggest posting in the regions section of this forum.
Q: What does it cost?
A: $350 up depending upon the shop you get and your level of mods.
Thanks.
Michael in KC
I hope that helped. I went from 405 rwhp to 432 with a good dyno tune.
Old May 8, 2008 | 12:08 AM
Cozmo's Avatar
Cozmo
The results I posted are not typical as my car is heavily modded.
Check out this thread for what cars closer to stock gain with a tune.
http://forums.corvetteforum.com/show....php?t=2008578
Old May 8, 2008 | 12:21 AM
Cozmo's Avatar
Cozmo
OK,
one more thing. I am trying to think about this from a person new to this type of things perspective so bear with me.
They hook up a laptop computer to your ECM (Engine Control Module) the computer that controls you car. They can turn off things like tire pressure sensor monitoring and on a M6 the CAGS (Computer Aided Gear Selection System).
They can also adjust the shift points in and shift firmness in an automatic car, when you cooling fans come on, and some many other paramaters to help improve your cars performance and driveability. Once all these changes are made, they save them to you ECM and the changes are permanent unless a dealership or some other shop messes with your ECM. Make sure your tuner saves your tune just in case.
I hope my rambling has helped.
Old May 8, 2008 | 12:23 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
unless you have modified your car a dyno tune is a waste of money
jacks996's Avatar
jacks996
Jacks996
look on youtube and type in corvette dyno
Old May 8, 2008 | 12:27 AM
Cozmo's Avatar
Cozmo
This is the comment from the OP of the thread above.
Originally Posted by MagRedConv
Just got back from Henderson Performance from my tune this am.
I don't have a Vista compatable printer/scanner yet so I can't post the sheet but here's what it wound up being:
Baseline - 283 rwhp
After magic performed - 312.48 rwhp, 321.81 max torque
The shifts are firmer and there's NO hesitation when the acc is depressed. This is the best $350 I've spent on my car.
Old May 8, 2008 | 12:32 AM
mbroadway's Avatar
mbroadway
Very interesting info. Thanks for the details.
How do they shift it while it's being tested if you have a manual transmission?
Old May 8, 2008 | 12:41 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Just like that
itzza427's Avatar
itzza427
I think some of the guys got a little carried away.To get to the basics,They strap the car to a chassis dyno that gets spun by the rear wheels in our case. Thus the term rear wheel hp.Then the computer wizzards hook up and can tune timing,air fuel curves and all kinds of stuff.They can optimize any and all operating paramiters,or tune for specific performance ideals or engine mods.factory specs are a compromise and can usually be improved upon.When you add cam,heads or headers,the factory tune doesn't/can't take advantage or make full use of these improvements and that's where the computer guys come in and they use the dyno to get the best out of the combos. It's strapped down with the rear wheels on the dyno rollers that have a calculated mass that takes energy to move(thats how the power is calculated) they drive it just like it's on the road.they go through the gears to 4th which is 1 to 1(direct drive) ratio 5th and 6th is overdrive
To Dyno Tuning... what is it?
