I'm no expert, but spending $50 would just be a waste of money. About the only thing that could possibly come in a kit is longer bolts and pre-cut bushings. This is one of the easiest mod's I've ever done...just turn the bolts and down she goes.
What is the difference between cutting the rubber bushings off and buying a $50 lowering kit?
About $50!
Seriuosly though;
Measure the ride height at all 4 wheels. Lower the car as much as possible an equal amount of turns with stock adjusters. Drive car for a few days. Re-measure ride height. If not low enough look in the previous posts for lowering or re-post here. Someone will help you. BTW: longer bolts for the rear can be bought for around $6. Do not ever, ever cut the rear bushings.
