Help with upgrades... Phoenix chime in
Old May 9, 2008 | 11:47 AM
stlchevy97's Avatar
stlchevy97
Default Help with upgrades... Phoenix chime in
I am coming up on a bonus in a few months and have around 15 to 20k to put into my car. its a 2002 z06 with 16,000 miles. i am pretty set on getting the 2.6l kenne bell package that comes with cold air kit, rk sport hood, 42lb injectors, flash tuner, 76-93mm inlet and a boost a pump. should put me around 569 rwhp and 557 rwtq properly tuned.
besides these upgrades i plan to add JET-HOT Coated Long Tube Header System w/ Random Tech High Flow Cat's, X-Pipe and corsa tigershark exhaust.
what do i need to do to make this safe to drive. hardend main shaft? DTE differential strut kit? i want to spend the least amount possible. will my stock z06 be able to handle 600 rwhp without breaking?
also does anyone know a good shop around Phoenix to install and tune this properly
any help you can give me in making this decison would be greatly appreciated
Casey
Old May 9, 2008 | 12:09 PM
hotwheels57's Avatar
hotwheels57
Are you in NC or AZ? If the latter, XTREME MOTORSPORTS (site supporting vendor) in Tempe, AZ is your best bet.
Old May 9, 2008 | 12:27 PM
stlchevy97's Avatar
stlchevy97
i just did a PCS from north carolina to Yuma AZ. thanks for the tip ill look into them.
Old May 9, 2008 | 01:43 PM
Juicdta's Avatar
Juicdta
yes extreme motorsports is your only option if you want to take it too a shop. ask for steve or jason to work on your car. steve is a buddie of mine and both are great guy's.
Old May 9, 2008 | 02:40 PM
hotwheels57
You might also check into shops in San Diego. Doing that much work is going to take a few days/weeks and you might enjoy the beach more than the desert...
Old May 9, 2008 | 02:56 PM
stlchevy97's Avatar
stlchevy97
i spoke with someone at xtreme and they seem to offer reasonable prices. i am going to get a quote to knock everything out at once. thanks again for the recommendation.
any advice on what i will need to keep out of the shop. i dont street race but i would like to go to the track without snapping something
Old May 9, 2008 | 03:29 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
with that kinda bonus, are they hiring????
Old May 9, 2008 | 03:56 PM
stlchevy97's Avatar
stlchevy97
Sure just go to your local recruiter and join the United States Marine Corps
Old May 9, 2008 | 03:59 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Old May 9, 2008 | 05:01 PM
hotwheels57
... Thanks for your service, by the way!
Old May 9, 2008 | 08:35 PM
dobewillie's Avatar
dobewillie
again a big thanks and get with a good speed shop for your best possible options
To Help with upgrades... Phoenix chime in
