[Z06] Serpentine belt squeall
May 10, 2008 | 12:18 AM
My sepentine belt started squealling so I replaced the belt witha gates. car stop squealling for a few days but now is back. Today I replaced the alternator and belt tensioner and it still squealls. what gives it only does this at around 4k rpms. Any help is appreciated
May 10, 2008 | 05:17 PM
check to see if the crank pulley is bent.
May 10, 2008 | 07:20 PM
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Been driving in the rain? If the belt gets dirty, it'll squeal.
Carb cleaner is your friend
May 10, 2008 | 09:02 PM
CI 3-5-6-7-8 Veteran
I had a squeek from hell that wouldn't go away... replaced the tensioners etc, but finally a buddy said try a Gatorback belt.... it worked perfectly.
May 11, 2008 | 10:57 AM
Take a bar of soap around inside of belt--always worked for me
May 11, 2008 | 11:23 AM
Quote:
Originally Posted by
bobby777
Wow, doesn't that make the belt slip even more? (I've always used soap as a lubricant)
May 11, 2008 | 05:38 PM
Cobra4B
Gatorback belts are designed to run quieter than most belts.
Check out their website.
http://www.goodyearbeltsandhose.ca/r...backpolyv.html
May 11, 2008 | 07:24 PM
I always put a spoon full of comet or other powder cleanser on several spots on the pulley facing the belt.It cleans the road film & oil film off nicely.No "Cherp".
\db2
Carolina
May 11, 2008 | 08:01 PM
How do you know it's not an actual tensioner?
I had both the serpentine tensioner AND the a/c idler tensioner go bad on my WS6.
Another option to consider..
May 11, 2008 | 08:12 PM
I think is't STP they make a spray called belt dressing.You spray it on the inner belt, stops noise.
