Ever since I installed my heads/cam/nitrous/3.42's/stall/trans I get this really loud chirping sound. It mostly happens when I floor it. If I do it from a stop, it will really screech, almost like the tires are spinning against the asphalt. Sometimes it will do it when it shifts from 1st to 2nd. The worst part is, I can be driving along at around 30 mph and if I floor it, it will still spin the tires. Is there anything I can do about this?
have you tried it on dirt or gravel that should help get rid of chirping sound , not that i would want to because it may make other sounds that are worse mine has the at problem also when i step real hard on the go pedal , so i just make sure that their or no cars with the cherries on top around when it happens to me oh and sometimes it cause smoke to appear around the tires
oak
Yeah, those guys don't seem to have an "appreciation" for that.
