[Z06] Battery Dead Again
Old May 13, 2008 | 07:17 PM
ZeeOSix's Avatar
ZeeOSix
Originally Posted by SweetZO6
Scrivs......take the positive terminal off the battery and put an AMP meter in series with the battery post and the terminal. Should read only a few milliamps for computer memory, etc.. If you are drawing more then .5 AMPs with everything off, then you have something that has possibly shorted causing excessive current draw. Just leave the amp meter connected and start pulling fuses one at at time. When the current draw drops, there is you culprit. People will add accessories and put them to the BATTERY side of the ignition switch vice the IGNITION side. Measure the current draw and post what it is. We can tell you if it is excessive. I have my XM radio and police scanner wired to the battery and have left them on for a week. The Optima still kicked the Z over.
Ed
The normal parasitic current draw should be 18~20 mA (0.018~0.020 A). Let all the computers “go to sleep” (takes about 15 minutes) before seeing what the real draw is.
TAC mentioned that his Red Top was out of the car on a Battery Tender, and after it was charged it self-discharged in a day or so on the bench. That's definitely a defective battery if it self discharges that fast out of the car!!
Old May 14, 2008 | 01:14 PM
Scrivs's Avatar
Scrivs
Thanks for all the advice guys. I will let u know how I make out. So far so good and I tossed the trickle charger aside (bad advice from Cdn Tire guy). I have a buddy coming over with a voltmeter and will check the draw at the post/terminal and pull fuses if necessary. Hopefully that isn't the case, cause I don't have any add ons, she is bone stock. I appreciate all the responses, it helps a lot to get advice from people that aren't out to sell you something and have different motives.
Old May 16, 2008 | 08:46 PM
Ward1's Avatar
Ward1
Don't buy your battery from 1stoptimabatteries.com They make you pay shipping to return it even if it is defective.
Old Nov 6, 2008 | 06:31 PM
Shylor's Avatar
Shylor
Once again I had a dead battery today. My car has been on a Sears (clone type battery tender) on it all year. I started it fine about a month ago. Not sure why the tender didn't keep the battery up to a full charge but it has done this one other time before....hmmmm.
Anyone know where I can get a deal on an Optima? Think I want to try a Yellow Top this time, as I had a Red Top on another vehicle that wasn't driven much and it died just outside of the warranty period.
Old Nov 7, 2008 | 09:03 AM
TEXHAWK0's Avatar
TEXHAWK0
Originally Posted by TAC
Interesting--but I don't think that explains everything. I got my 2nd replacement Red Top and put it on my wood workbench. My Battery Tender brought it up to 13.2 volts overnight so I removed the tender and let the battery sit on my workbench all by itself. The next morning it was down to 11.73V. The battery simply didn't hold its charge and it was brand new. If it takes some special tender to keep it alive why would I believe a simple alternator would then keep it fully charged? I'll stick to my Delco...
I agree. With more Optima batteries in service, people are finding they fail just like any other battery, and the quality may not be as good as most thought.
ACDelco Professional grade batteries have a 50 month full replacement warranty, and their quality seems to be improved. I also will just keep my Delco battery. I did have a cell go bad after 3 years, and the local parts store gave me a brand new battery, no charge.
Old Nov 7, 2008 | 10:38 AM
briann510's Avatar
briann510
I still have my original battery and it has never gone dead or failed to start the car even after sitting for a month or more at a time. I don't need no stinking battery tender either. If a battery needs a tender on it then there is something wrong in the system somewhere draining it.
Old Nov 7, 2008 | 07:03 PM
Shylor's Avatar
Shylor
Please don't be ignorant. C5's have computer systems that draw juice even when the car is not running. In 2 to 3 weeks time it drain a battery that is not driven daily. If you drive your car all the time then there is no question your battery will last a long time. But garage queens need some sort of battery tender on their battery. For some reason my OEM battery failed, even with a battery tender type device on it. But a question has been raised as to why GM no longer uses the AGM style batteries......high failure rates perhaps?
Old Nov 7, 2008 | 07:50 PM
Red ZEE06's Avatar
Red ZEE06
My original lasted about 2 yrs. My Z06's are not daily drivers and get laid up for a month or more every other month or so.
I now use "Walmart batteries, guaranteed full replacement for three years! Although I haven't had to use the warranty.
Whenever I lay up the car I just disconnect the positive terminal with a battery terminal wrench, cover the battery terminal with the plastic plug that came with it! Takes about a minute. All I lose is the clock setting. Radio presets have always stayed put. They start up every time. I find his works better for me than the Battery disconnects which I've tri3ed but have not always worked properly!
Old Nov 7, 2008 | 08:09 PM
Shylor's Avatar
Shylor
I am just so pissed at how expensive a car battery has gotten these days. Seems like batteries 20 and 30 years ago lasted much longer and of course were way much cheaper. Granted I understand vehicles today have more electronics in them that work when the car is not running. Still, here we are in the 21st Century and we still get dead batteries?
Old Nov 8, 2008 | 12:21 AM
ctusser's Avatar
ctusser
The 21st century is all about profit and companies that make things that last forever are not as profitable in the long run. That's why a modern appliance only lasts 10 years and the one Grandma bought in the 1950's is still going.
But I'll recommend an Odyssey battery, they won't be damaged by a complete discharge and aren't much more expensive than a regular battery.
Old Nov 8, 2008 | 03:55 AM
briann510's Avatar
briann510
Ignorant? I stated above my car is not started for a month or 2 at a time frequently and the battery is never dead and its 5.5 years old. Whats ignorant about that comment? I don't care if the cars computer systems draws juice when sitting as I have 7 other vehicles that sit weeks or months at a time as well and they are not dead either when I go to start them and they all have computer systems as well. It is not normal for a cars battery to go dead just from sitting several weeks. Thats a crock of sh** if thats happening and there is a fault somewhere.
Old Nov 8, 2008 | 06:38 PM
Shylor's Avatar
Shylor
This is your statement that makes you ignorant. As actually it is very normal for the AGM C5 battery to go dead after sitting for several weeks. This has been known since the C5 first used the AGM battery and you would have known this if you had followed the forum threads starting back in 2003. Just because other vehicles use computers doesn't mean the system is the same as the C5.
Old Nov 8, 2008 | 08:32 PM
  #33
bobby777's Avatar
bobby777
stinkin battery tender? Dude we will see you on the interstate--but your ride will be to the side of the road
Old Nov 8, 2008 | 10:18 PM
  #34
briann510's Avatar
briann510
The only time I'm sitting on the side of the road is when a cop is standing next to my window...
Well since I have a 2003 with the original AGM battery still in it the comment above "AGM batteries go dead after sitting a few weeks" in simply untrue at least in my case (and I know lots of other people still having theirs as well).
My AGM is 5+ years old is still going strong (and I bet it goes the whole 7 years it was designed to go)...I guess I should have replaced it years ago when car was new since its no good according to past forum threads...
It just hit or miss with batteries. Some are good and some are bad right from the get go but no newer car should have to have a tender on it cause of a drain over a couple weeks. Flip a coin.
Ok, I couldn't resist so I went out and took a picture of my POS AGM battery that shouldn't have lasted the first 6 months in 2003. I'll leave it in till it goes dead which probably wont be for another couple years.
Old Nov 9, 2008 | 12:57 AM
  #35
Shylor's Avatar
Shylor
If you are talking about my statement, then I was talking about AGM's in cars that are not driven daily. My 03 Z06 barely has over 3,000 miles on it, so it is a garage queen that hasn't always had a battery tender type device on it. The battery had run down a few times and had to be fully charged back up. So maybe when I finally did get one of those devices on my battery it was to late, as the damage had already been beyond repair for a tender to work.
I am sure AGM's work fine for cars driven all the time, just not for long term storage cars. Then again if this battery was so good, then why did GM decide not to use them anymore?
