C5 drivers mirror replacement
couldn't find one.
thanks
fred
Good Luck
Mirror Replacement
Removal Procedure
Caution
Disconnect the power window switch when working inside the driver's door. When operated, the Express Down Feature allows the door window to drop very quickly, without stopping, which could cause personal injury.
Lower the door window.
Remove the door trim panel. Refer to Trim Panel Replacement - Door .
Removal Procedure
Important
To reduce the chance of damage to the trim panel leave the switch in the panel until after the panel is removed from the door.
Remove the inside handle bezel. Refer to Handle Bezel Replacement - Inside .
Remove the pull handle plug.
Remove the screws behind the pull handle plug.
Notice
Insert the fastener removal tool between the male fastener, which is attached to the trim panel, and the female retainer, which is in the door. Incorrectly inserting the tool between the head of the female retainer and the door will break the fasteners.
For better sight access to the fasteners start by first prying out the fastener at the rear of the trim panel that is approximately 50 mm (2 in) up from the trim panel seam. Pry out the remaining trim panel fasteners working your way forward.
Lift the trim panel up off the upper retainers and reposition the panel by the door.
Remove the harness connector from the switch.
Remove the trim panel with absorber, switch, and speaker grill.
Remove any trim panel upper retainers that remained on the door.
Transfer parts as necessary.
Installation Procedure
Reinstall any loose upper retainers to the door trim panel.
Position the trim panel near the door and install the switch harness to the switch.
Install the trim panel to the top of the door engaging the upper retainers.
Align all the trim panel side and lower fasteners with the retainers in the door.
Press the trim panel firmly to the door at each fastener location.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the screws behind the pull handle. Tighten
Tighten the pull handle screws to 6 N·m (53 lb in).
Install the pull handle plug.
Install the bezel to the handle.
Position the bezel around the inside door handle.
Push firmly on the bezel to engage the locking tabs to the door.
Remove the door radio speaker assembly.
Remove the screws mounting the speaker assembly.
Disconnect the electrical/audio connector.
Remove the mirror nut access plugs.
Disconnect the electrical connector(s).
Disconnect the mirror harness from the retainers.
Remove the nuts from the mirror studs.
Remove the mirror with the harness and gasket.
Caution
Position the mirror with the gasket and harness to the door.
Notice
Install the nuts to the mirror. Tighten
Tighten the mirror nuts to 10 N·m (89 lb in).
Route the harness and secure the harness with the harness retainers.
Connect the electrical connector(s).
Install the mirror nut access plugs.
Install the uppermost screw mounting the radio speaker assembly to the door.
Install the remaining screws in a criss-cross pattern. Tighten
Tighten the door speaker assembly screws to 2.5 N·m (22 lb in).
Connect the electrical/audio connector.
Connect the speaker connectors.
Install the door trim panel. Refer to Trim Panel Replacement - Door .
Removal Procedure
Pull the door inside handle open to access the openings to the bezel locking tabs.
Insert a screwdriver in the lower opening. Tip the screwdriver up while pulling on the bezel releasing the lower locking tab.
Insert the screwdriver in the upper opening. Tip the screwdriver down while pulling on the bezel releasing the upper and the forward locking tabs.
Grasp the bezel firmly, pull the bezel releasing the rear locking tabs.
Remove the bezel.
Push firmly on the bezel engaging the bezel locking tabs to the door.
http://forums.corvetteforum.com/show...hlight=tlgarst
